SIA Reference Sheet
Recently I've been fixated with figuring out when to use which SIA, especially considering it's now either SIA or Bolter Discipline. So, I made a spreadsheet, ran some numbers, and made a reference sheet I could use to figure out which ammo I could expect to give me the most wounds in a given situation.  The sheet considers not only toughness and distance, but also considers SIA v Bolter Discipline, and gives the next best option for when Hellfire Rounds or Bolter Discipline can't be used.
Here's my handout, https://i.imgur.com/7Rbx1MY.jpg
I'm pretty confident in my numbers, but I suppose things could be wrong. What do you all think? Is this something useful to you all?
https://bolterandchainsword.com/topic/356141-sia-reference-sheet/
I like this. Nice and handy to bring with you to a game. Good to have if you are new to the army or can't really play that often like me. =)
You don't have it in a little bit higher resolution?
For me I think this is one of those things that should be pinned in the DW forum. Things to aid you in your game, along with alternative bits and such. =)
