GreyCrow Posted May 31, 2019 Share Posted May 31, 2019 Hi all ! i’m converting a Primaris Lieutenant model for my chapter for a tournament. Quick question : what is the base size ? The Primaris Captain is on a bigger stand (Inceptors size) as per my Interdiction battleforce Which base size are Primaris Lieutenant ? 32mm or the same as the Primaris Captain ? Thanks ! Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/ Share on other sites More sharing options...
Lord Raven 19 Posted May 31, 2019 Share Posted May 31, 2019 The same (40mm) Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5323478 Share on other sites More sharing options...
GreyCrow Posted May 31, 2019 Author Share Posted May 31, 2019 Thank you sir ! Follow up question I’m forgetting to ask : Same process for a Primaris Ancient ? 32mm or 40mm ? Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5323491 Share on other sites More sharing options...
Oxydo Posted May 31, 2019 Share Posted May 31, 2019 Primaris Ancient also goes on a 40 mm base. Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5323531 Share on other sites More sharing options...
Lord Raven 19 Posted May 31, 2019 Share Posted May 31, 2019 The above is correct Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5323538 Share on other sites More sharing options...
GreyCrow Posted May 31, 2019 Author Share Posted May 31, 2019 Many thanks gentlemen Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5323579 Share on other sites More sharing options...
Gederas Posted June 1, 2019 Share Posted June 1, 2019 Basically, all (current) Marine Characters are on 40mm bases with some exceptions (Typhus, Lord of Contagion and Primarneus Calgar being on 50mm bases, Abaddon being on a 60mm). Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5323698 Share on other sites More sharing options...
Closet Skeleton Posted June 3, 2019 Share Posted June 3, 2019 Dark Imperium Lord of Contagion is on 50mm but the Tainted Cohort one comes with 40mm. New Dark Apostle is on 40mm, Death Guard characters are inconsistent but many are on 40mm. Link to comment https://bolterandchainsword.com/topic/356305-primaris-lieutenant-base-size/#findComment-5325233 Share on other sites More sharing options...
