Iron warrior standing outside armored door of enemy fortification: "Knock knock. "
Enemy inside fortification.  "Whose there? "
Iron warrior: "Just wanted"
Enemy: "Just wanted who? "
Iron warrior: "Just wanted to make sure someone was standing on the other side of this door. " Iron warrior then sets off breaching charge.
https://bolterandchainsword.com/topic/356399-iron-warrior-humor/
When you end up with a minimum of 10x the logistics needed for a "simple" military operation.
You get annoyed when there is something 20  seconds behind the schedule/ timetable, you go on a rampage amongst the flesh when the delay stretches to a few minutes.
Your warpsmith curses you out when you forget to put hazard stripes on your weapon to indicate its not stock, needing non standard replacement parts when going for wargear maintenance.
The look on the Imperial Fists face as you open up with your bolter with the spare  bane-strike rounds you have been holding on to since the drop-site massacre for a "special occasion".
A loyalist marine and a traitor walk into a bar.
The bartender says "We don't serve dark angles here! "
The mechanicus is basically "Yo Dawg, the Brotherhood of Steel from Fallout but with a higher focus on the acolytes instead of the Knights/guys in power armor"
Iron warriors created the darkest thing in the universe? I don't think they started realty TV....
