dbecer01 Posted June 8, 2019 Share Posted June 8, 2019 If I airbrush contrast paints, will I get similar results to if I brush them on? Or are they really meant to be painted on? Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/ Share on other sites More sharing options...
Bryan Blaire Posted June 8, 2019 Share Posted June 8, 2019 According to some of the topics/videos elsewhere on the Internet and a thread where it was discussed here, airbrushing the Contrast paints doesn't give you much, if any, of the actual Contrast effect and instead seems to produce an almost tint/clear paint quality with them. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5327961 Share on other sites More sharing options...
Fajita Fan Posted June 8, 2019 Share Posted June 8, 2019 https://youtu.be/i1zSQdAnqoM Skip to the end if you’re curious but it’s not a long video. This stuff sounds like matte acrylic ink. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5328003 Share on other sites More sharing options...
dbecer01 Posted June 8, 2019 Author Share Posted June 8, 2019 Wow, that stuff has some interesting properties! Do they replace glazes completely? Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5328009 Share on other sites More sharing options...
Bung Posted June 8, 2019 Share Posted June 8, 2019 Airbrushing that stuff isnt interesting. You can get same and better results with other colors. Same goes fir glazing. You can glaze with any color with some acrylic binder and water. Only thing those colors have is the availability in GW stores. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5328137 Share on other sites More sharing options...
dbecer01 Posted June 8, 2019 Author Share Posted June 8, 2019 Acrylic binder as in airbrush/acrylic medium? Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5328166 Share on other sites More sharing options...
Bung Posted June 8, 2019 Share Posted June 8, 2019 Its the part of the paint that binds the pigments to the surface. If you just thin your paints with water to make them a glaze you lose the bonding capacity for the paint too, so you could rub of the pigments while doing other glazing layers. I mix 1 part paint with 3 parts acrylic binder and thin them down how i need it with water. Bonus: you can use acrylic binder with pigments to mix your own paints. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5328238 Share on other sites More sharing options...
Tyberos the Red Wake Posted June 8, 2019 Share Posted June 8, 2019 Wow, that stuff has some interesting properties! Do they replace glazes completely? Pretty much. They said they're discontinuing Glazes because Contrasts exist. They do seem slightly different from Glazes, but I bet you can make them work similarly enough if you need a true glaze, and they already do the job of "Glaze and Shade only" style paintjobs. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5328392 Share on other sites More sharing options...
Evil Eye Posted June 12, 2019 Share Posted June 12, 2019 I can see the inherent translucency of Contrast working quite well for airbrushing, particularly for getting very subtle tints and gradients, kinda like a clear paint with matte medium (except more convenient and in more colours). I'm sure you can get similar results with inks and medium but for convenience's sake it's worth trying at least. I'd be interested to see it "wet-blended" by airbrushing some on and then doing the same with another colour whilst the former is still wet. I did that with a currently WIP Nurgle Rhino with regular paint and got some very unusual and rather cool mottling effects. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5330495 Share on other sites More sharing options...
Fajita Fan Posted June 12, 2019 Share Posted June 12, 2019 It looks like this stuff needs pool into recesses like a shade to give the contrast effect, the video I saw airbrushing the stuff made it look so flat it just looked like transparent paint. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5330522 Share on other sites More sharing options...
Arkhanist Posted June 12, 2019 Share Posted June 12, 2019 Yeah, airbrushing it will act just any other translucent paint. Potentially useful if you have it already and/or want that exact shade, but it's an expensive per-ml clear coat; warcolours transparent paint, createx candy, tamiya clears, badger ghost tints will all do the same effect for cheaper. I'm not sure wet blending after airbrushing will work that well, as having it stay fluid for any length of time means you'll also risk it spidering all over. For a mottled effect I did see this video where the guy sponged it on, and that does look pretty cool if that's the effect you're after (he was trying to work around the visible brush stroke problem with Contrast on a tank) And he also mixes the Contrast medium with nuln oil, and normal paint. Diluting nuln oil with normal medium or flow aid does *not* have this result in my experience (it might go on thin, but you run serious risk of tide marks), so I can definitely see myself nicking that idea. Link to comment https://bolterandchainsword.com/topic/356479-airbrush-contrast-paints/#findComment-5330531 Share on other sites More sharing options...
