Wolf Lord Loki Posted June 11, 2019 Share Posted June 11, 2019 Was going through my faqs a little while ago and spotted this little gem in the Index of Chaos faq Q: There is no datasheet for a Herald of Nurgle on a Palanquin of Nurgle – which datasheet should I use for this model? A: Use the Epidemius datasheet from Index: Chaos Would you say just use the stats and weapons of Epidemius to represent the palequin and use the herald as normal (not the Talley rule), or could you use a herald as effectively a back up Epidemius (a herald without pysker abilities? Link to comment https://bolterandchainsword.com/topic/356541-herald-of-nurgle-on-a-palequin/ Share on other sites More sharing options...
DeStinyFiSh Posted June 11, 2019 Share Posted June 11, 2019 It pretty much means you can use the Herald on Palanquin as an alternative model for Epidemus. Which means 1 per army whith exactly Epidemus rules. Link to comment https://bolterandchainsword.com/topic/356541-herald-of-nurgle-on-a-palequin/#findComment-5329700 Share on other sites More sharing options...
tychobi Posted June 13, 2019 Share Posted June 13, 2019 Your model is now officially a "special " character! Link to comment https://bolterandchainsword.com/topic/356541-herald-of-nurgle-on-a-palequin/#findComment-5330622 Share on other sites More sharing options...
