Kierdale Posted June 21, 2019 Share Posted June 21, 2019 For three large bases I wanted to try to paint green marble, and thought I’d try using cork for a bit of an experiment... I first basecoated the cork with cheap art paint, Ivory. Then tried Waywatcher Green Glaze, concerned that Biel Tan Green Shade would be too dark... The former turned out too light, and the latter just right. So I redid them all with Biel Tan, then drybrushed them heavily with the Ivory, ...then White. And finally two coats of gloss varnish. Different angle I think they’ll look better with the base rims repainted black and put some debris and other stuff on there -will try to do that soon and take new photos - but what do you think so far? I’m happy with it. Not ecstatic but happy. Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/ Share on other sites More sharing options...
Quixus Posted June 21, 2019 Share Posted June 21, 2019 It looks good for stone, for marble I think it would need some more veins and a smoother surface. Unpolished marble looks quite unimpressive. Using the same technique with a grey or brown colour would probably make great granite. Maybe use a different colour for the seams to emphasize that they are different tiles. Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5335003 Share on other sites More sharing options...
Gederas Posted June 21, 2019 Share Posted June 21, 2019 I've also seen a good method for painting marble using sponges. Sadly, I think the website that the tutorial was on is now defunct..... I remember the method enough to be able to do it for my Knights when I get around to painting them though. Once I get around to painting them, I could also post the method here? Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5335082 Share on other sites More sharing options...
Kierdale Posted June 21, 2019 Author Share Posted June 21, 2019 On 6/21/2019 at 1:38 PM, Gederas said: I remember the method enough to be able to do it for my Knights when I get around to painting them though. Once I get around to painting them, I could also post the method here? Please do so. Or in a new thread if it’s not using cork, that way it might get more attention (or at least be better labelled ;) ). Looking at the bases 24hrs on, I consider them an interesting experiment, but I’m not going to keep them. Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5335160 Share on other sites More sharing options...
Chaplain Mollusc Posted June 21, 2019 Share Posted June 21, 2019 I don't think it much resembles marble, but it does look like some of the high-end semi-rough-surfaced tile I've seen in various places. I like it, and shall be stealing the idea at some point. :) Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5335314 Share on other sites More sharing options...
Gederas Posted June 22, 2019 Share Posted June 22, 2019 On 6/21/2019 at 8:38 PM, Chaplain Mollusc said: I don't think it much resembles marble, but it does look like some of the high-end semi-rough-surfaced tile I've seen in various places. I like it, and shall be stealing the idea at some point. Ever seen unpolished marble? This is actually pretty accurate to what unpolished marble looks like. It's far more glossy, but that's fairly accurate. Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5335418 Share on other sites More sharing options...
Brother-Chaplain Kage Posted June 24, 2019 Share Posted June 24, 2019 Here's one of the best tutorials I've seen for faux marble at 40k scale. https://www.youtube.com/watch?v=dGAywWej_vQ Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5336368 Share on other sites More sharing options...
The Ergonomic Enginseer Posted June 24, 2019 Share Posted June 24, 2019 Keeblerartillery does some great marble if you find his Carmine Blades wip on this site. Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5336759 Share on other sites More sharing options...
Kinstryfe Posted June 25, 2019 Share Posted June 25, 2019 I haven't successfully gotten a coloured marble yet, but I mixed up 1/2 glazing medium and 1/2 matte medium, along with some white paint. I thin it to apply as a glaze, and by going from a silver base with black squiggles thru a couple layers of glaze - squiggles - glaze and finally some black ink thin squiggle touchups it gives a great white marble finish. I'm not sure if that could be adapted to green or other colors. Link to comment https://bolterandchainsword.com/topic/356714-green-marble-using-cork/#findComment-5336920 Share on other sites More sharing options...
