Good pin vice drill bit set at Walmart fairly cheap.
I have that very set that I use with my Dremel on a regular basis. Note for anyone buying this to use with your Dremel: You will have to buy the collet set to be able to use the majority of these in the Dremel.
I use the smallest ones in my pin vice as well, but I also use them in my Dremel pretty regularly. It greatly speeds up things like drilling holes in the feet of numerous figures which I then hold with a hemostat for priming and my pin vice handle for painting.
