Jerethdatiger Posted June 27, 2019 Share Posted June 27, 2019 I'm hopi g to get some help. Regarding emperors spears. How am I supposed to do rank plumes on gravis inceptor armor please help Link to comment https://bolterandchainsword.com/topic/356841-how-do-i-model-rank-plumes-on-inceptor-armour/ Share on other sites More sharing options...
The Yak Posted June 27, 2019 Share Posted June 27, 2019 Hail Brother There is an in depth look at Aaron's thoughts on the Chapter in the log linked below. http://www.bolterandchainsword.com/topic/331042-emperors-spears-covered-by-a-d-b/?do=findComment&comment=4657538 Aaron is often there and may asnswer your question directly if you are lucky. Hope this helps Link to comment https://bolterandchainsword.com/topic/356841-how-do-i-model-rank-plumes-on-inceptor-armour/#findComment-5338387 Share on other sites More sharing options...
KrautScientist Posted June 29, 2019 Share Posted June 29, 2019 I think you should use some kind of transversal creat that goes on top of the carapace above the head, not unlike what you see on the Captain in Gravis armour from Dark Imperium, only less metallic and more like a horsehair crest. There's a bit that would be perfect in the Mk. III Marines kit, although suitable horsehair crests are also available from all kinds smaller companies. Hope this helps! Link to comment https://bolterandchainsword.com/topic/356841-how-do-i-model-rank-plumes-on-inceptor-armour/#findComment-5339155 Share on other sites More sharing options...
