I'm trying to apply decals to Kazem's Retinue of the Wayward Sons. I'm using Thousand Sons decals and squad markings off of the Space Marine Transfer Sheet (currently testing with Tactical arrows). On my test model, the Thousand Sons emblem went on fine. However, I've tried like three times with the arrow, and it won't smooth. Solutions?
https://bolterandchainsword.com/topic/357192-decal-smoothing-help/
I’d make sure you’re cutting the decal as close as you can to what you want to use. Excess decal on pauldrons makes for wrinkly-sticky-uppy headaches.
Micro sol and micro set are your friends, too, if you’re not using them, yet. Use the blue one to apply it, and the red one sparingly to flatten in in place.
A bit of a process but if you're serious about getting them to look decent then it's worth it;
Apply 2 coats of gloss varnish to the area where the decal is going to be
Trim the decal as close to the design as possible
Apply the decal and brush on some micro sol
When dry, apply a coat of matt varnish
