Understanding Mont'ka . help needed.
BolterZorro
Here are the rules from the codex:
Once per battle, at the beginning of
your turn, a single COMMANDER from
your army can declare either Kauyon
or Mont’ka:
Mont’ka: Friendly <SEPT> units within 6"
of the COMMANDER can both Advance
and shoot as if they hadn’t moved this turn
Here is what I understand:
1. I declare mont'ka at beginning of my turn
2. I move normaly, eventually with an advance.
3. as mont'ka say "can advance if they hadn't move" I can advance once again (free additional advance then)
4. In shooting phase, I shoot as if those units didn't move at all.
Am I correct? Some of my friends understand this as "I can only shoot as If I didn't move", with NO additional/free advance.
What is the "consensus"? Is there a faq or something that clarify mont'ka?
https://bolterandchainsword.com/topic/357249-understanding-montka-help-needed/
No you don't get a free advance. The only thing this does is let units shoot with rapid fire and heavy weapons even if they advanced, and with assault weapons without hit-penalty if they advanced. Nothing there says that you can advance again.
What @sfPanzer said. Mont'Ka removes the negative effects of moving (with or without an Advance), so you can fire all guns without penalties.
Effectively, "both" is used as a conjunction, with "and" separating the clauses. Note going Vior'la already grants you part of this.
