GuardDaddy Posted August 4, 2019 Share Posted August 4, 2019 We have a large number of WIP threads on the forum. 19 Oct is Armies on Parade. Anyone up for creating a board to display there armies so far and sharing WIP as they do so? Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/ Share on other sites More sharing options...
Kierdale Posted August 4, 2019 Share Posted August 4, 2019 I entered my IG into AoP2018: I used a cork noticeboard about 60cm x 40cm, from the local 100yen store for the board, and paper-clay (again from the 100yen store) to sculpt it a bit. Some thick card across one corner for a bit of road. Painted it all with cheap craft store acrylic paints. I kept it all cheap as, with an IG army, likely most of the board will be covered (particularly if, like me, you can’t resist the temptation to fit your entire army on the board!). The only real terrain piece I added was a statue I squeezed into one corner: I hope that helps, and I’d love to see everyone’s entries. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5357666 Share on other sites More sharing options...
GuardDaddy Posted August 4, 2019 Author Share Posted August 4, 2019 Awesome. I'm going to have same issue of lots of models. Think.im going to add city ruins from GW and have army bursting out from them. I am thinking of ways of adding vertical presentation areas for visual interest - balconies, maybe a raised area. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5357715 Share on other sites More sharing options...
Kierdale Posted August 4, 2019 Share Posted August 4, 2019 Good thinking. More terrain will make it more believable. Less like they’re fighting on Planet Tabletop. ;) Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5358198 Share on other sites More sharing options...
CommissarZac Posted August 6, 2019 Share Posted August 6, 2019 Oh my 38th Landsknecht Rifles will certainly be represented. I have to grab a cheap poster board like you. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5359808 Share on other sites More sharing options...
ScionOfCorlesia Posted August 7, 2019 Share Posted August 7, 2019 Will be entering again this year with my Militarum Tempestus. Entered for the first time last year, pretty plain board with my dudes on top. Got a few plans for a Scene this year rather than just my lads on display. That's the plan anyway.. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5360793 Share on other sites More sharing options...
GuardDaddy Posted August 8, 2019 Author Share Posted August 8, 2019 Sounds great. I'm looking forward to doing some terrain. I also want to share fluff of my regiment so going to have some info text on side of board, so going to do a deeper board. Not sure yet by adding a simple frame that will also help rigidity. The models are done. Also conscious of transport. I have a fair bit of GW scenery to use from various sources. At the minute plan is to have back of base with ruined buildings and arranging models as they charge out of that. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5361531 Share on other sites More sharing options...
GuardDaddy Posted August 17, 2019 Author Share Posted August 17, 2019 OK starting to flesh project out now. I've collected up 40k scenery I have and can get quite a high stack set up to add vertical height Got the board from B&Q (UK) for 12 quid. Here is layout test I have seen what I can get on model wise without overcrowding board It will allow for some nice little mini scenes to be set up within board NEXT STEPS: I'm going to spray paint baseboard, and then add low level scatter scenery. Below are links to useful stuff I've found for this Pavement to go around buildings - https://ttcombat.com/collections/city-scenics/products/pavement-set Tank Traps - https://www.waylandgames.co.uk/28mm-scenery/18117-anti-tank-traps?search_query=tank+trap&results=21 Sandbags - https://ttcombat.com/collections/sci-fi-gothic/products/sandbags Imperial Street Lights! https://www.waylandgames.co.uk/kromlech-tabletop-scenics/64407-hive-city-street-lights Harbour Grating - to use as street - https://ttcombat.com/collections/gaming-boards/products/harbour-grating-sections Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5369065 Share on other sites More sharing options...
duz_ Posted August 17, 2019 Share Posted August 17, 2019 Looking forward to seeing it completed Also curious to see what those sandbags look like Good luck :tu: Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5369139 Share on other sites More sharing options...
GuardDaddy Posted August 23, 2019 Author Share Posted August 23, 2019 Ok order arrived and led to slight change in layout. Now doing a crossroads. MDF scenery great, resin good too. Images of testing layouts below, will obvioulsy cut new MDF scenery boards to size to fit 2 foot square base board. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5373187 Share on other sites More sharing options...
duz_ Posted August 23, 2019 Share Posted August 23, 2019 That looks great! :tu: Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5373192 Share on other sites More sharing options...
Lundholm Posted August 27, 2019 Share Posted August 27, 2019 I entered my IG into AoP2018: I used a cork noticeboard about 60cm x 40cm, from the local 100yen store for the board, and paper-clay (again from the 100yen store) to sculpt it a bit. Some thick card across one corner for a bit of road. Painted it all with cheap craft store acrylic paints. I kept it all cheap as, with an IG army, likely most of the board will be covered (particularly if, like me, you can’t resist the temptation to fit your entire army on the board!). The only real terrain piece I added was a statue I squeezed into one corner: I hope that helps, and I’d love to see everyone’s entries. Love your flyer, do you have any WIP pictures of it? Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5375595 Share on other sites More sharing options...
GuardDaddy Posted August 28, 2019 Author Share Posted August 28, 2019 ok, cracked on as school term and family life about to hit until October. Finished With army on it Some mini dioramas set up on board Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5375830 Share on other sites More sharing options...
duz_ Posted August 28, 2019 Share Posted August 28, 2019 That looks great! Good luck :tu: Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5375941 Share on other sites More sharing options...
ScionOfCorlesia Posted August 28, 2019 Share Posted August 28, 2019 Looking absolutely fantastic. Given me a kick to get my finger out and crack on with mine. Good luck, I'm sure you'll do well. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5376069 Share on other sites More sharing options...
Kierdale Posted August 31, 2019 Share Posted August 31, 2019 Great work, Guard Daddy. The best of luck to you for Parade Day! Lundholm, WIP images (and some background) for my flyer - the Martlet (counts-as-Lightining) start about HERE in my army thread. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5378373 Share on other sites More sharing options...
FelipeFlops Posted September 2, 2019 Share Posted September 2, 2019 Have posted some of these elsewhere but will put them up here for posterity. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5379910 Share on other sites More sharing options...
Bjorn Firewalker Posted September 2, 2019 Share Posted September 2, 2019 Excellent work, FelipeFlops. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5380044 Share on other sites More sharing options...
FelipeFlops Posted September 3, 2019 Share Posted September 3, 2019 Excellent work, FelipeFlops. Have spent too much of my life making mini parades for them Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5380619 Share on other sites More sharing options...
GuardDaddy Posted October 19, 2019 Author Share Posted October 19, 2019 And finished Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5410690 Share on other sites More sharing options...
lionofjudah Posted October 21, 2019 Share Posted October 21, 2019 Can't make my images small enough right now to upload to BnC... My 3.5k points of solar Auxilia are at my GW LGS right now Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5411317 Share on other sites More sharing options...
duz_ Posted October 21, 2019 Share Posted October 21, 2019 Can't make my images small enough right now to upload to BnC... My 3.5k points of solar Auxilia are at my GW LGS right now If you're in your phone theres plenty of free photo resizing apps otherwise paint is always a handy option :tu: Looking forward to seeing your pics GD looks great :tu: How'd did you place? Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5411343 Share on other sites More sharing options...
Kolgrim DeathHowl Posted October 21, 2019 Share Posted October 21, 2019 Great looking army! Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5411354 Share on other sites More sharing options...
lionofjudah Posted October 25, 2019 Share Posted October 25, 2019 Thanks Duz!!! Done things I don't think about Here we go, back down the rabbit hole.... So, my LGS usually does AoP at the end of October so I'm resting easy and gently plugging along on the for soldiers and planning on a tiered display base this year... Happy go lucky till I look in the shops FB feed on a Friday and see that I only have 1 week Needless to say I quit sleeping and put in 24 hours of painting in that week to almost get finished with the command squad... Anyhoo... Here we go Can't make my images small enough right now to upload to BnC... My 3.5k points of solar Auxilia are at my GW LGS right now If you're in your phone theres plenty of free photo resizing apps otherwise paint is always a handy option :tu: Looking forward to seeing your pics GD looks great :tu: How'd did you place? Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5414254 Share on other sites More sharing options...
gilt_imp Posted October 26, 2019 Share Posted October 26, 2019 Congratulations to those who entered the Armies on Parade. All the pics in this thread look fantastic, so much effort and inspiring, so well done! Unfortunately, I did not get to enter the AOP, the store manager did not allow it. Due to where I live and the nearest store being over 500km away, I rang the store to check on some things before going there, as driving that far and booking a hotel etc I wanted to make sure I got things right, like entry times etc. When we phone talked about my entry the store manager told me sorry, he had a no FW policy. That meant no FW kits at all, to play with or even for entry into painting events, like the AOP. As I had designed my entry around the large FW Porphyrion knight, he gave me a choice, replace that knight with something else or not enter. Well it was a bit hard to suddenly come up with a replacement. Anyway, at least I found out before I drove there! That would have sucked even more!!! Btw I have since checked with GW, apparently stores (individual store managers) have the right to allow FW kits in their store or not allow them. I think I’ve heard something like that before, just didn’t realise it included painting events as well. Now I know. Link to comment https://bolterandchainsword.com/topic/357511-armies-on-parade-imperial-guard/#findComment-5414772 Share on other sites More sharing options...
