Brother Tyler Posted August 12, 2019 Share Posted August 12, 2019 Here is the initial stab at tokens/markers for the Kill Team game. The one thing holding me back right now is that I haven't figured out what graphic(s) to use for the various xenos Commander Aura tokens. The forces of the Imperium use a laurel; the forces of Chaos use a Chaos star stylized as a laurel. If I can't figure out a decent generic graphic to use for all xenos factions/sub-factions, I may have to come up with different graphics for each xenos faction/sub-faction (which will slow me down, but that's okay if it's for the best). Normally I show a Commander Aura and Psychic Effect token, but lacking the Commander Aura graphic, here's the objective marker: Genestealer Cults Note that this is a generic GSC icon. If there are different icons and color schemes for different cults, I'll probably create those, too. I expect that I'll create a range of GSC icons for the different hive fleets (matching those colors, look in the Tyranids forum). Thoughts? Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/ Share on other sites More sharing options...
JeffJedi Posted August 22, 2019 Share Posted August 22, 2019 These look nice. Just a suggestion, maybe the top of the Magus staff or something would make a good icon. Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/#findComment-5372277 Share on other sites More sharing options...
Brother Tyler Posted April 30, 2020 Author Share Posted April 30, 2020 I tried some alternatives with a few of the xenos factions, but was dissatisfied with them. So last night I pushed this rock further up the hill. These will be expanded so that there are tokens matching the schemes of the Tyranid hive fleets. I might adjust the basic design by shrinking the Genestealer Cult icon a bit. Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/#findComment-5514870 Share on other sites More sharing options...
Axineton Posted April 30, 2020 Share Posted April 30, 2020 Think it looks better without the laurel mate. Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/#findComment-5515129 Share on other sites More sharing options...
Brother Tyler Posted May 2, 2020 Author Share Posted May 2, 2020 I removed the laurel. The file is now available for download here. Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/#findComment-5515719 Share on other sites More sharing options...
Zephaniah Adriyen Posted May 2, 2020 Share Posted May 2, 2020 How would you go about printing these as proper tokens? I'm interested in having a set of these sometime. Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/#findComment-5515883 Share on other sites More sharing options...
Brother Tyler Posted May 2, 2020 Author Share Posted May 2, 2020 In theory, they can be printed double-sided and cut out with a different marker on opposite sides (commander aura/psychic effect, move/advance, etc.). If I was going to do that, I'd probably use heavy cardstock and then laminate them after cutting them out. Alternately, you can print them on separate sheets of paper and then glue different markers for a double-sided effect, either to each other or to something like wooden discs (available at hobby shops), old bases (gluing two bases together will give you a token that's easier to pick up, but much thicker), etc. Or you can print them on sticker paper to stick them directly to the object. Link to comment https://bolterandchainsword.com/topic/357662-genestealer-cults-tokensmarkers-for-kill-team-wip/#findComment-5515893 Share on other sites More sharing options...
