Russian Color Scheme for Cadian Models
Hey mates. I have my IG Army progressing very well and after some much thought, I decided to make my own Regiment and I like the idea of using on modernized Russian theme. Will be using Cadian models as my Infantry and with that being the case, what do you think would be a good color scheme for them to match the Russian-Theme?
Plan to use this to test it out, so please specify the colors of the Fatigues and the armor.
http://www.bolterandchainsword.com/igpbeta2.php
I took a quick look at camopedia and I'm guessing you're aiming for a forest pattern like this:
http://camopedia.org/images/1/1b/Russia43.jpg
The painter's preset color options are very out-of-date, but you're looking at Caliban Green for dark green, Warpstone Glow or Moot Green for light green (the latter will pop more, but is less of a match for the actual camo color), Doombull Brown for the brown, Zandri Dust for the khaki, and Abaddon Black for the black. However, I recommend taking a read through this previous post on painting camo and narrowing down the scheme you want to a base plus two or three colors. For example, green base with camo pattern of light and dark brown with some black areas.
