Redwunzgofasta Posted August 24, 2019 Share Posted August 24, 2019 Hi all, Recently I posted a question about mk2 armour, thanks for all the replies and advice Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/ Share on other sites More sharing options...
Marshal Rohr Posted August 24, 2019 Share Posted August 24, 2019 If you do Mark 3 and want to stay in line with the White Scar themes, a cool avenue of approach would be a mechanized assault group. Mark 3 Legionaries with bolters and combat blades in sections of 30 in Rhinos with Heavy Bolters. An elite detachment of Ebon Keshig in a Mark2b Phobos Land Raider escorting the Commander, and add Jetbikes to taste. Maybe go light on dreadnaughts, since they would have difficulty keeping open with an armored column moving in open country. An assault gun section of 2-3 vindicator with siege shields could give you a cool Siege of Terra theme. A rapid reaction force moving against traitor breakthroughs. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373561 Share on other sites More sharing options...
Closet Skeleton Posted August 24, 2019 Share Posted August 24, 2019 Mark 2 and 3 are Great Crusade era suits that shouldn't be very common by the mid heresy but the simple fact is that a tabletop force is too small a portion of a Legion to need to look statistically representative. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373623 Share on other sites More sharing options...
Marshal Rohr Posted August 24, 2019 Share Posted August 24, 2019 Mark 2 and 3 were the most common suits during the Heresy, with mark 4 only having been rolled out in the decade prior. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373637 Share on other sites More sharing options...
Redwunzgofasta Posted August 24, 2019 Author Share Posted August 24, 2019 @Marshal Rohr thanks Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373646 Share on other sites More sharing options...
Johanhgg Posted August 24, 2019 Share Posted August 24, 2019 I’m using mkIII for my scars. If someone tells me I’m doing it wrong, they shall only receive “the stare”. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373655 Share on other sites More sharing options...
Redwunzgofasta Posted August 24, 2019 Author Share Posted August 24, 2019 I’m using mkIII for my scars. If someone tells me I’m doing it wrong, they shall only receive “the stare”. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373685 Share on other sites More sharing options...
Brother Pheidias Posted August 24, 2019 Share Posted August 24, 2019 I'll counter the others slightly and instead ask what you want out of your scars.I began mine with a fairly classical tacticals-in-rhinos set-up, but that was never what drew me to the Scars. Instead, I know run a lot of Jetbikes (Prohibitively expensive, believe you me, I know!), because it's really the mounted archer-style of an all-mounted Chogorian Brotherhood that I want to play. And the dong-bikes look spectacular.On the armour marks, the V. were very elusive, infrequently and opportunistically resupplied, so anything goes, but older marks are probably preferable, even if I mainly use Mk. 4 on the Jetbikes, with sergeants ("Dharga", in Korchin I believe) and other veterans tending to mk. II and III. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5373843 Share on other sites More sharing options...
carlisimo Posted August 26, 2019 Share Posted August 26, 2019 In Scars, Shiban wears Mk III. So there. It was developed early enough that the White Scars certainly would've had it, even if their faster units would have preferred Mk II. Not your fault it's not easily available anymore. The only problem is that bikes or jetbikes other than Shamshirs come with Mk IV, and Shamshir jetbikes don't look easily convertible to Scimitar weapons. But it's probably easier and cheaper to do that than to buy Scimitars and swap out the riders. Don't feel obligated to use bikes, though. The Kyzagan's Mk II riders will work fine alongside Mk III. I'm also a big fan of mixing in Mk V parts with Mks II and III. Link to comment https://bolterandchainsword.com/topic/357925-planning-white-scars-plea-for-advice/#findComment-5374644 Share on other sites More sharing options...
