Interrogator-Chaplain Ezra Posted August 24, 2019 Share Posted August 24, 2019 Just a quick check, I'm pretty sure I know the answer. Infiltrator Comms Array: This references *Phobos Captains* and *Rites of Battle* Chapter Master stratagem: Turn a Captain into a Chapter Master if there are other Chapter Masters in your army. Thesis: Turn a Phobos Captain into a Chapter Master, and his lads refuse to pick up the phone (the ICA no longer works on him), since he no longer possesses Rites of Battle. Thoughts? Link to comment Share on other sites More sharing options...
Slasher956 Posted August 24, 2019 Share Posted August 24, 2019 Not a SM player so don’t have the dex....but Why does he lose rites of battle? Is that stated in the strat? Or do you replace the data sheet with a separate one? If the later then the captain would also lose the Phobos armour Link to comment Share on other sites More sharing options...
Claws and Effect Posted August 25, 2019 Share Posted August 25, 2019 Not a SM player so don’t have the dex....but Why does he lose rites of battle? Is that stated in the strat? Or do you replace the data sheet with a separate one? If the later then the captain would also lose the Phobos armour The Strategem replaces the Rites of Battle rule with the Chapter Master rule. Everything else on the datasheet remains the same. RAW: No, the Comms Array would no longer work. RAI: ?!? ( Link to comment Share on other sites More sharing options...
ShinyRhino Posted August 26, 2019 Share Posted August 26, 2019 Sounds like it's working as intended when you lose RoB for CM. I feel there's a game balance issue when you start rerolling everything regardless of bubble aura distance. Link to comment Share on other sites More sharing options...
Panzer Posted September 2, 2019 Share Posted September 2, 2019 Confirmed by the freshly released FAQ: Q. If I upgrade my Captain in Phobos Armour to be a ChapterMaster, should the Infiltrator Comms Array still work with thismodel, and with its Chapter Master ability instead of Ritesof Battle?A: No. Interrogator-Chaplain Ezra 1 Back to top Link to comment Share on other sites More sharing options...
