Mcha0s92 Posted September 3, 2019 Share Posted September 3, 2019 Do you find a squad of intercessors armed with stalker rifle useful in your lists? I think the stratagem has a too high cost to be relied upon Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/ Share on other sites More sharing options...
casb1965 Posted September 3, 2019 Share Posted September 3, 2019 2CP to double your shot output sounds bad until you think if you're within 15" your 10 man unit is kicking out 40 shots at D2 and -1 AP and if you're in Tactical doctrine that becomes -2 AP. Imperial Fist players benefit even more with "ignoring cover" and "6s = 2 hits", with average rolls that's 33, -2AP D2 hits. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5380730 Share on other sites More sharing options...
Oxydo Posted September 3, 2019 Share Posted September 3, 2019 2CP to double your shot output sounds bad until you think if you're within 15" your 10 man unit is kicking out 40 shots at D2 and -1 AP and if you're in Tactical doctrine that becomes -2 AP. Imperial Fist players benefit even more with "ignoring cover" and "6s = 2 hits", with average rolls that's 33, -2AP D2 hits. Stalkers are Heavy 1 and aren't affected by neither bolter discipline nor Tactical Doctrine. Their strat also gives them the sniper rule but doesn't double their shots. On topic, I don't really see the point in Stalkers since 3 CP for 10 sniper shots is quite expensive, and you can buy actual full time snipers if you need that. The lack of shots and being heavy starts hurting when advancing in tactical doctrine compared to the two other options so I'm not going to add stalkers to my list but that's because my playstyle is focused on melee to mid-close range. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5380739 Share on other sites More sharing options...
Captain Idaho Posted September 3, 2019 Share Posted September 3, 2019 A backfield Intercessor squad with Stalkers can plink away at heavier targets and cause a handful of wounds but really you'll want Eliminators for that and get your Intercessors in close. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5380767 Share on other sites More sharing options...
Closet Skeleton Posted September 3, 2019 Share Posted September 3, 2019 The damage 2 makes them decent at softening up light and medium vehicles and will come into its own if Primaris face offs start becoming common in the meta. Haven't used the stratagem yet but the damage 2 ap-2 is a massive boon over scouts. Camo cloak sniper scouts are similar in cost to intercessors anyway. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5380797 Share on other sites More sharing options...
Panzer Posted September 3, 2019 Share Posted September 3, 2019 It's an okay-ish alternative if you expect to face some more heavy infantry. These days it's best to just go with Auto Bolt Rifles though. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5380804 Share on other sites More sharing options...
Prot Posted September 3, 2019 Share Posted September 3, 2019 I don't know about the Strategem but I find them very useful against high end infantry. Their in all my lists and with Ultra's, as a troop choice that can run and gun, I find that very useful. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5380871 Share on other sites More sharing options...
librisrouge Posted September 3, 2019 Share Posted September 3, 2019 It's an okay-ish alternative if you expect to face some more heavy infantry. These days it's best to just go with Auto Bolt Rifles though. I just adore whenever we see numbers like this on the forum. It seems especially appropriate on the Ultramarine subforum. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381093 Share on other sites More sharing options...
BLACK BLŒ FLY Posted September 4, 2019 Share Posted September 4, 2019 They are really good with the Devastator doctrine. If I ran a third squad I’d definitely run them with stalkers. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381267 Share on other sites More sharing options...
Stickeh Posted September 4, 2019 Share Posted September 4, 2019 It's an okay-ish alternative if you expect to face some more heavy infantry. These days it's best to just go with Auto Bolt Rifles though. These numbers are very helpful, thanks! I’ve been modelling my intercessors with bolt rifles but it looks like autos are the way to go, barring the double fire stratagem on a unit of 10. Sadly i think the stalker bolt gun stratagem is just too expensive when eliminators exist. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381417 Share on other sites More sharing options...
Lemondish Posted September 4, 2019 Share Posted September 4, 2019 It's an okay-ish alternative if you expect to face some more heavy infantry. These days it's best to just go with Auto Bolt Rifles though. These numbers are very helpful, thanks! I’ve been modelling my intercessors with bolt rifles but it looks like autos are the way to go, barring the double fire stratagem on a unit of 10. Sadly i think the stalker bolt gun stratagem is just too expensive when eliminators exist. It's definitely not something you want to build a list around or even plan to use every game, but if you're running Stalker rifle Intercessors for other reasons anyway then the Strat can be of use from time to time. It is far more situational compared to the rapid fire one, and the opportunity cost is high, but if you need to down a linchpin character don't forget about this one. 3 CP is expensive, but if paying it puts you on a much easier path to winning the match then it would be CP well spent Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381440 Share on other sites More sharing options...
Prot Posted September 4, 2019 Share Posted September 4, 2019 It's an okay-ish alternative if you expect to face some more heavy infantry. These days it's best to just go with Auto Bolt Rifles though. These numbers are very helpful, thanks! I’ve been modelling my intercessors with bolt rifles but it looks like autos are the way to go, barring the double fire stratagem on a unit of 10. Sadly i think the stalker bolt gun stratagem is just too expensive when eliminators exist. Actually that's exactly the thought process I had. Then I realized as Ultra's the Bolt Rifles (starting T2) are shooting 2x a turn at 30" with AP-2. The Auto Bolt Rifle Strat is okay, but the new strats are just so much better, and with Aura's it's hard to justify the CP cost. So I built one squad of Stalkers, and I don't have any regrets. The thing here is it's not always about the math. Autohitting flyer/or negative modifier units (which are everywhere on the competitive scene) is very valuable. However facing multi wound elite units is also a big thing in my area. And I like the 36" (there also the 'option' of sniping characters). My conclusion: GW did a very respectable job of making the 'uncommon' Bolt Rifle types much more usable. :) Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381597 Share on other sites More sharing options...
crazyterran Posted September 4, 2019 Share Posted September 4, 2019 With the Rapid Fire strategem and Ultramarines double tapping up to 30 on the move, Assault Bolters still beat them for UM? The extra 1PPM though... Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381735 Share on other sites More sharing options...
Kallas Posted September 4, 2019 Share Posted September 4, 2019 With the Rapid Fire strategem and Ultramarines double tapping up to 30 on the move, Assault Bolters still beat them for UM? The extra 1PPM though... Statistically...kind of. Once UM Scions of Guilliman comes into play, they're better against different targets: Vs GEQs: BR: 2*0.66*0.66 = 0.871 wounds/17pts = 19.5pts/wound ABR: 3*0.66*0.66*0.833 = 1.089 wounds/18pts = 16.5pts/wound Vs MEQs: BR: 2*0.66*0.5*0.66 = 0.436 wounds/17pts = 39pts/wound ABR: 3*0.66*0.5*0.5 = 0.495 wounds/18pts = 36.4pts/wound Vs TEQs: BR: 2*0.66*0.5*0.5 = 0.33 wounds/17pts = 51.5pts/wound ABR: 3*0.66*0.5*0.33 = 0.327 wounds/18pts = 55pts/wound BRs are pretty decent all rounders; ABRs are actually still pretty damn good against similar targets, but when saves get to 2+ then the BR edges out a little bit. I think the Tactical Doctrine and extra shot really do make ABRs an excellent weapon now; especially as they're firing their 3 shots all of the time, vs the BR getting 2 only at half range or under Scions. Edit: Missed the part about Rapid Fire: once that gets added into the equation then they become much more effective, but then there's an additional CP cost, and the opportunity cost that only one unit can use RF in each phase (in Matched Play). To figure out how good RF BRs are...just double the wounds caused/halve the points per wound above! Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5381751 Share on other sites More sharing options...
Link2edition Posted September 17, 2019 Share Posted September 17, 2019 I put some sticky tack on the rifles where the magazine goes and just swap out the variants as I please so I don't have to pick which to build.The fit is snug enough you really don't even need magnets, just a little bit of stick. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5391103 Share on other sites More sharing options...
Seahawk Posted October 2, 2019 Share Posted October 2, 2019 I've built one 10 man squad with rifles, still debating how to build the next 10: all of any of them, or half n half of Stalkers/ABRs. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5400062 Share on other sites More sharing options...
Stiff Crayons Posted October 2, 2019 Share Posted October 2, 2019 I've built one 10 man squad with rifles, still debating how to build the next 10: all of any of them, or half n half of Stalkers/ABRs. I’d suggest creating squads with uniform weapon options. Max squads (10 models) will get the most mileage from the strategems. Five stalkers using Target Sighted might be a little underwhelming and not worth the 3 cp. Might as well go all-out and take ten models if you intend on using the strategem. Link to comment https://bolterandchainsword.com/topic/358149-stalker-pattern-bolt-rifles/#findComment-5400202 Share on other sites More sharing options...
