Guilliman or Calgar?
ThatOneMarshal
Hey everyone! I’ve been running ultras recently and I’ve been trying to figure this out. So in general we want to have a full re roll on our units, especially in larger games as well as command points.
I was curious gameplay wise do you guys prefer running the Calagar or guilliman to lead your army.
Calagar seems to have the advantage of providing an easier way into a list with him being an HQ and all. He also seems great for his warlord trait. However he is restricted to being only 6 inches and needs a lieutenant to go around with him.
He’s also cheaper which is a huge plus.
Guilliman has the advantage of being a CC beast and also very capable allowing more mobility in your army considering his 12 inch re rolls. He’s much hardier as well. However he limits you to only two detachments as he will take up the third either being in a super heavy auxiliary or a supreme command. Also he’s expensive.
So what do you guys think, or do you all prefer taking a chapter master upgrade from a captain?
https://bolterandchainsword.com/topic/358193-guilliman-or-calgar/
Depends on what kind of army you're running. How competitive do you want to be? I can honestly see both being used in different ways.
IMHO: Guilliman works best with moving castles. He provides the punch they need to make melee a dangerous option.
I've not seen Calgar's new rules yet though. But I know he is good. It is freaking Calgar.
Calgar + LT is almost a hundred points cheaper base and fills your HQ slots. They arent as punchy, but then you aren't wasting 90+ points on more HQ slots (two techmarines are 90pts), adding another 100~ points to Guilliman's cost, especially if you don't want Techmarines!
I suppose you could use Guilliman to offset needing to take another Batallion for points, saving CP Cost of a CM + he gives you 3, balancing it out. However, is Guilliman better for your army than 15 troop bodies + two HQs, plus the additional slots that go with the Batallion?
Calgar does also save the CP expenditure of Chapter Master too and still gives 2CP, and is an HQ towards a Battalion.
I'm glad Guilliman's buff is no longer insanely potent, but I feel like Calgar+Lt, plus other stuff is the better option.
See the only thing I’m thinking right now is if it’s worth it to go with guilliman for the mobile gun line.
In my first game of ITC I realized that mobility seems to be extremely important, making it so that castling isn’t nearly as effective.
What do you all think, can we do the mobile gun line with Calagar or is guilliman our only way forward?
So far I agree. It's a close call but I think they changed his Hand of Dominion to partially compensate for how much less effective dad's firesword is going to be.
For me it was one thing to remove the re roll all wounds aura (I think it had to happen), but I would have kept it on the sword. It's the Emperor's sword... and it is made of fire... it burns.
So when I was after big targets, or something like Mortarion, the sword -was- the absolute go to, 100% of the time, and I just banked on getting the Mortal wounds. Now not so much. Again, I think that's why the Hand of Dominion was buffed.
I've seen too many games where Guilliman isn't pulling his weight under the new rules, and the points are considerably different from Calgar (+ the additional HQ you're going to have to buy)
That being said I'd still use him in the right list. It's not like he's 'bad' or anything like that. Just perhaps not an auto include in all lists like before.
If Guilliman can benefit from +1 to wound from Chaplain he can still wound Mort on 2+. He is still the best melee unit you has to be a little careful now.
Anyone eschewing Calgar over Roboute to save points on HQ does not understand this edition. Plus we have some. very tasty HQ.
Further to my point, I think you could probably get 3 squads of Aggressors instead? I only use one, but it’s nit just about the points. It’s about what the rest of the army can do now. Aggressors are amazingly potent for Ultramarines.
Add in Shock assault, added resilience, and their extra attacks, I’ve had to start pulling these guys from my lists. People sometimes want any part of these guys. I save them for highly competitive games now. They used to pretty bad. I’d struggle to find a way to get them in a list.
Again it’s the totality of rules....not just points. You ever wander into 350 points of Aggressors overwatching you with a Calgar Aura? Add in combined overwatch.... especially from a Repulsor variant...nasty.
I don’t think Guilliman is ‘bad’. Not by a long shot. But while he’s been turned down a touch, so many other things have had a multilayered buff.
Guilliman is good, the big problem is the fact that he's a Lord of War.
With all the great strats available to Astartes, and the fact that we're looking to build a mono faction army means that you'll be taking multiple additional HQs to unlock at the very least a Battalion.
We end up spending 500-600 points on characters before we've bought a single unit that can score points or attack at range. Careful list building is required.
People are spending 500-600 points on characters?
I thought I was splurging buying my CM a relic blade instead of a power sword.
A Captain/CM, a LT, a Chaplain and/or a Librarian. I guess if you are going for the Lord Macragge and Tigurius that’s 350 points right there. On the other hand, you can get a classic CM and Librarian for 160-170 and 2cp... and as UM we have ways to generate extra CP.
I try my best to keep my Librarians out of melee... bad things happen.
Anyways 150 points seems well worth it to me for the buffs and debuffs.
I meant instead of Tigurius/Calgar - it's 350 for Tiggy and Calgar, 171 and 2cp for my CM/Librarian.
