Dwango Posted September 5, 2019 Share Posted September 5, 2019 Hello all. I'm looking to convert/kitbash a knight tyrant. I gone through many blogs a pictures and found some amazing examples. It's going to be a dedicated to nurgle so will be pretty weathered etc. I'm wanting to try and achieve a similar paint scheme/effect to this Can anyone tell me how the texture on the armour panel was achieved please? It looks as though it was added before painting but I could be wrong with that. Thanks Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/ Share on other sites More sharing options...
Marshal Loss Posted September 5, 2019 Share Posted September 5, 2019 You can get a similar effect by applying sand/grit prior to painting. I used to mix plastic glue with a little bit of sand and smear it around on selected areas of my Nurgle vehicles. You can then use a toothpick/drill to manipulate the melting effect of the glue. Pigments/weathering powders will help you place emphasis where desired. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382392 Share on other sites More sharing options...
Marshal Rohr Posted September 5, 2019 Share Posted September 5, 2019 S P I K E S Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382401 Share on other sites More sharing options...
Dr_Ruminahui Posted September 5, 2019 Share Posted September 5, 2019 It also looks like they used a drill and/or a knife to make the depressions. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382408 Share on other sites More sharing options...
Dwango Posted September 5, 2019 Author Share Posted September 5, 2019 You can get a similar effect by applying sand/grit prior to painting. I used to mix plastic glue with a little bit of sand and smear it around on selected areas of my Nurgle vehicles. You can then use a toothpick/drill to manipulate the melting effect of the glue. Pigments/weathering powders will help you place emphasis where desired.Ah, that makes sense. I did think it could be sand but wondered how it was applied without leaving lots of glue about. Using the plastic glue to create the melting effect is clever. Thanks. S P I K E SHaha, spikes are a definite and I have already added a few. Need to do more though! It also looks like they used a drill and/or a knife to make the depressions.That's what I was thinking but I couldn't work out how they made it look like the paint was bubbling away as well. It's a really good effect! I'm going to have to do a few test pieces I think. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382438 Share on other sites More sharing options...
Brother-Chaplain Kage Posted September 5, 2019 Share Posted September 5, 2019 Here's a way to add some texture with Tamiya putty from the scale modeling side of things. https://youtu.be/SQZUtjNQXjg?list=PLdMxG_XHdQUa26CwwqfuoxlOWejD0L-nw&t=654 https://www.youtube.com/watch?v=0-kqLtRGhUQ&list=PLdMxG_XHdQUYIV7XwzdqQBT-ZPa4aRoO7&index=2 You could also brush some plastic cement (NOT superglue) over an area you want some sunken texture on and let it sit for a couple minutes to soften up the plastic. Take a brush with stiff bristles and and stipple the area which will add a grainy texture to the area. Once you like the look of it, let it sit for half an hour to harden back up. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382444 Share on other sites More sharing options...
NovemberIX Posted September 5, 2019 Share Posted September 5, 2019 Krylon makes textured "stone finish" spray paints in course and fine grain that would probably make for a good overall texture that you can build up from. The divots can also be made with a metal tool and hammer if you have a way to clamp and brace the body panel you're working on so you don't need to use a lot of force, or possibly have it deflect and go flying. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382466 Share on other sites More sharing options...
Isengrin Posted September 5, 2019 Share Posted September 5, 2019 Vallejo red oxide paste is used quite often to create texture. On a smaller scale, typhus corrosion works great too and I use it on every mini. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382528 Share on other sites More sharing options...
Magos Takatus Posted September 5, 2019 Share Posted September 5, 2019 I think liquid green stuff is more effective in creating texture than filling gaps. Here's a Tabletop Minions video on it. https://www.youtube.com/watch?v=cK97CLGFwY4 Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382570 Share on other sites More sharing options...
RikuEru Posted September 6, 2019 Share Posted September 6, 2019 I think liquid green stuff is more effective in creating texture than filling gaps. Here's a Tabletop Minions video on it. I can only recommend this technique. You can make very gritty, stony surfaces with this, but also organic ones, as if it was covered with moss, flesh or fungus. I have even seen someone do slightly scale-y textures with it or rows of sinews over on Instagram. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382687 Share on other sites More sharing options...
Dwango Posted September 6, 2019 Author Share Posted September 6, 2019 Thanks for all the advice! There are some very useful videos and techniques that have been posted. I actually have a pot of liquid green stuff that needs using, as I've found it's useless for actually filling gaps! So I think I'll give it a try out. I may do a mixture of techniques to get the desired effect. I want it to look like it's been decaying for thousands of years. There's a lot of armour panels to go at!! Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5382764 Share on other sites More sharing options...
Verux Posted September 9, 2019 Share Posted September 9, 2019 I used the liquid green stuff technique for adding corrosion to my nurgle tanks and vehicles. I simply took a sponge and dabbed it on until I was satisfied. Plenty of work time. It works very well and added with some rust and chipping it will shine. Link to comment https://bolterandchainsword.com/topic/358214-advice-on-how-to-chaosify-a-knight-tyrant/#findComment-5385133 Share on other sites More sharing options...
