Morticon Posted September 9, 2019 Share Posted September 9, 2019 I'm pretty sure I know the answer to it (just hoping ive missed some exception), but ..... if a GSC player uses laying in wait and deploys a unit within 3", is there any chance to get off Auspex scan before Perfect Ambush triggers? Seems like they both happen immediately after setting up, which means its the GSC player's chance to resolve first :/ Someone prove me wrong..please. Link to comment Share on other sites More sharing options...
shanewatts Posted September 9, 2019 Share Posted September 9, 2019 (edited) I'm pretty sure I know the answer to it (just hoping ive missed some exception), but ..... if a GSC player uses laying in wait and deploys a unit within 3", is there any chance to get off Auspex scan before Perfect Ambush triggers? Seems like they both happen immediately after setting up, which means its the GSC player's chance to resolve first :/ Someone prove me wrong..please. I agree that the GSC player (active players turn) should be able to determine the order between scan and ambush, since both are resolved immediately after setting up. Edited September 9, 2019 by shanewatts Link to comment Share on other sites More sharing options...
Demoulius Posted September 9, 2019 Share Posted September 9, 2019 Seems they both would be triggered by the same criterea (unit arriving from reinforcements) so the player whose turn it is (GSC in this case) would be able to decide what order it goes off on. Why is this an issue though? They get to move right up in your face as they are blasted to kingdom come? They cant come within 1 inch of you unless they charge though and that happens later on. So you can still fire at them. Or at the very least im fairly sure that they cant use that move to get within charge range Link to comment Share on other sites More sharing options...
Rogue Posted September 10, 2019 Share Posted September 10, 2019 Because Perfect Ambush also lets you shoot out of sequence. So you can use Lying in Wait to put 20 hand-flamers within range, then fire them before your opponent can do anything about it. Link to comment Share on other sites More sharing options...
Demoulius Posted September 11, 2019 Share Posted September 11, 2019 Ah yes I see, I had not read the 2nd half of perfect ambush. Boy thats nasty Link to comment Share on other sites More sharing options...
