Redwunzgofasta Posted September 9, 2019 Share Posted September 9, 2019 Hi all, I think I originally asked this in the wrong forum Link to comment https://bolterandchainsword.com/topic/358304-weapon-connection-question/ Share on other sites More sharing options...
Mike Zulu Posted September 9, 2019 Share Posted September 9, 2019 I think the Wraithlord, Guardian HWP and War Walker weapons are nearly identical, but not exactly. I typically put all heavy weapons into one pile, and then take from the pile when assembling new models. A few times I've had to cut the tab (on the weapon) a little bit shorter so it would fit into the slot (on the model itself). So, short answer: yes, but may require a small modification to the weapon. Link to comment https://bolterandchainsword.com/topic/358304-weapon-connection-question/#findComment-5384827 Share on other sites More sharing options...
Redwunzgofasta Posted September 9, 2019 Author Share Posted September 9, 2019 I think the Wraithlord, Guardian HWP and War Walker weapons are nearly identical, but not exactly. I typically put all heavy weapons into one pile, and then take from the pile when assembling new models. A few times I've had to cut the tab (on the weapon) a little bit shorter so it would fit into the slot (on the model itself). So, short answer: yes, but may require a small modification to the weapon. Brilliant, thank you! Link to comment https://bolterandchainsword.com/topic/358304-weapon-connection-question/#findComment-5384948 Share on other sites More sharing options...
