Son of Sacrifice Posted September 14, 2019 Share Posted September 14, 2019 As the title states Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/ Share on other sites More sharing options...
WarriorFish Posted September 14, 2019 Share Posted September 14, 2019 I've played against Tyranids a few times in KT, they have a lot of versatility. I can't give you details of course, but generally speaking you can put a good number of models on the table which gives you options. They move fast too so you can close in quickly which is good as combat is your main focus. Stealers are very good but be aware that they will be high targets so you'll need a few of them, try to make use of cover as much as possible ideally hiding completely as they advance as your opponent won't be able to ignore them. Are you set on only using stealers? For a pure stealer force I've not encountered one yet, but I imagine they will function much the same as other more elite KTs; lots of potential but some bad luck can change things quickly if you lose a couple of models quickly! Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5388523 Share on other sites More sharing options...
Interrogator Stobz Posted September 14, 2019 Share Posted September 14, 2019 I play against Nids a lot, they are fast and deadly but need a variety of dudes to peak. Add a couple of termagaunts for objective holding and if you play Elites a Hive Guard is a good shooter threat too. Nid Warriors are an ok and versatile choice, just don't waste them by waiting back and shooting, keep them moving into CC in support of the stealers. Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5388971 Share on other sites More sharing options...
Son of Sacrifice Posted September 15, 2019 Author Share Posted September 15, 2019 Termagaunts and warriors, can do. Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5389037 Share on other sites More sharing options...
Kilofix Posted September 15, 2019 Share Posted September 15, 2019 Most of the lists I’ve played against in Tourney have had a single Warrior, a single Lictor, 1 to 2 Genestealers and then a ton of Hormagaunts. Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5389053 Share on other sites More sharing options...
ShotgunFacelift Posted September 15, 2019 Share Posted September 15, 2019 This is what I play with regularly have had good experiences with against most other factions. ++ Kill Team List (Tyranids) [99pts] ++ + Configuration + List Configuration: Matched Play: Kill Team + Leader + Lictor [25pts]: Kraken . Leader + Specialists + Tyranid Warrior [22pts]: Deathspitter, Kraken, Scything talons . Comms Tyranid Warrior Gunner [24pts]: Kraken, Rending claws, Venom cannon . Heavy + Non-specialists + Hormagaunt [4pts]: Kraken Hormagaunt [4pts]: Kraken Hormagaunt [4pts]: Kraken Hormagaunt [4pts]: Kraken Hormagaunt [4pts]: Kraken Hormagaunt [4pts]: Kraken Hormagaunt [4pts]: Kraken ++ Total: [99pts] ++ Created with BattleScribe (https://battlescribe.net) Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5389214 Share on other sites More sharing options...
brother Vorn_GarDos Posted September 17, 2019 Share Posted September 17, 2019 i have played mostly genestealer kill team with a single lictor. The team used is mostly for fun and casual games. My advice is to get a warrior kit so you can create two CC warriors & one shooting warrior. The warriors give you access to better CC weapons with the genestealers. the kit also has a Tyranid Prime parts that can you can use as a kill team commander. Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5390505 Share on other sites More sharing options...
Dosjetka Posted September 17, 2019 Share Posted September 17, 2019 I'm curious as to why people recommend Hormagaunts over Termagants? All those extra bio-guns could put a dent in (almost) anything, no? Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5390596 Share on other sites More sharing options...
Son of Sacrifice Posted September 22, 2019 Author Share Posted September 22, 2019 Well I did my first game running only genestealers. Got absolutely destroyed. They really miss being able to advance and charge. I've got 3 warriors to build, and it looks like Hormagaunts will be in my immediate future. Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5394121 Share on other sites More sharing options...
brother Vorn_GarDos Posted September 25, 2019 Share Posted September 25, 2019 Well I did my first game running only genestealers. Got absolutely destroyed. They really miss being able to advance and charge. I've got 3 warriors to build, and it looks like Hormagaunts will be in my immediate future. ouch. it might have been you were playing with a veteran kill team player. if your goal is to win against competitive players then warrior and hormagaunts will be your immediate future. Link to comment https://bolterandchainsword.com/topic/358437-starting-a-tyranid-kill-team-advice-needed/#findComment-5395917 Share on other sites More sharing options...
