BlueBiscuit Raider Posted September 18, 2019 Share Posted September 18, 2019 I've got myself 2 of the Easy to Build plague marines trio from the Conquest 02, and I'm wondering how I should go about turning them into something more unique since i've already got those 3 sculpts builts as they are. In terms of extra parts I've only built 3 models out of the 7 plague marine box (a plasma gunner, a blight launcher marine and the flail marine), so I've got some bits to work with. Suggestions? Must do or don'ts? This will be my first time converting anything. Link to comment https://bolterandchainsword.com/topic/358540-1st-timer-advice-on-converting-plague-marines/ Share on other sites More sharing options...
MaliGn Posted September 18, 2019 Share Posted September 18, 2019 If it is the same as the general easy to build kit on the he site I'd say you could start by mixing out heads, possibly whole arms with bits from the general plague marine kit. You could try mixing up the belly plates, but that might need green stuff, fortunately a bit of messy green stuff won't be too noticeable on a death guard model while you learn how to use it! Link to comment https://bolterandchainsword.com/topic/358540-1st-timer-advice-on-converting-plague-marines/#findComment-5392055 Share on other sites More sharing options...
Exilyth Posted September 18, 2019 Share Posted September 18, 2019 Suggestions? Must do or don'ts? If using a knife: Have a medkit nearby, use a cutting mat to protect the surface you're cutting on and always cut away from your body. That aside, cutting through an arm between torso and shoulder let's you replace and/or repose that arm, which can help a lot with making poses more varied. Also: Cutting just before or after a joint tends to work better when recombining parts from different arms. Link to comment https://bolterandchainsword.com/topic/358540-1st-timer-advice-on-converting-plague-marines/#findComment-5392080 Share on other sites More sharing options...
Akylas Posted September 19, 2019 Share Posted September 19, 2019 I've been working on converting plague marines. I started with a copy of the chaos side of dark imperium and a plague marine box. Because both sets are designed to fit a certain way I've found I have to either trim a lot or add slivers of plastic (often cut from sprues) to get arms to fit properly. Link to comment https://bolterandchainsword.com/topic/358540-1st-timer-advice-on-converting-plague-marines/#findComment-5392493 Share on other sites More sharing options...
PeteySödes Posted September 20, 2019 Share Posted September 20, 2019 I'm a psycho so I always advise to attempt anything you have a vision for. If you fail, you learn and have a piece that you likely cant make worse thats begging to flex your GS muscles on. Most likely though you won't and will also learn I bet, but have a unique piece you can be proud of too. Don't rely too much on guides etc, trust your gut! Thats where the magic is. Link to comment https://bolterandchainsword.com/topic/358540-1st-timer-advice-on-converting-plague-marines/#findComment-5393335 Share on other sites More sharing options...
