High Density Foam (Pink Foam) - Best UK Supplier?
.Torch.
Just paint over it with some slightly watered down PVA/wood glue to seal. If you mix it with a base tone acrylic you can use it as a primer and a sealant in one fell swoop, so that if you want to spray you don't have to worry about foam melting.
