Mcha0s92 Posted October 3, 2019 Share Posted October 3, 2019 Hi i recently bought casan sabius and sirae karagon from the forgeworld red scorpions and i found the rules to field them, but in the pdf it says to play sirae karagon as a chapter ancient,but there is no more chapter ancient in the space marine codex, just the company ancient. So how should i field him now? Thank you Link to comment https://bolterandchainsword.com/topic/358934-sirae-karagon/ Share on other sites More sharing options...
Brother Tyler Posted October 3, 2019 Share Posted October 3, 2019 For those that are looking for the rules, you can see them here. https://www.forgeworld.co.uk/resources/PDF/Downloads/Sabius_Karagon__2017.pdf I would simply replace CHAPTER ANCIENT with COMPANY ANCIENT and fix the page number in the rule: To represent Ancient-Invigilus Sirae Karagon in all instances, the COMPANY ANCIENT datasheet should be used, as on page 126 of Codex: Space Marines. When doing this, replace the <CHAPTER> keyword with the RED SCORPIONS keyword. Link to comment https://bolterandchainsword.com/topic/358934-sirae-karagon/#findComment-5401074 Share on other sites More sharing options...
Mcha0s92 Posted October 3, 2019 Author Share Posted October 3, 2019 For those that are looking for the rules, you can see them here. https://www.forgeworld.co.uk/resources/PDF/Downloads/Sabius_Karagon__2017.pdfI would simply replace CHAPTER ANCIENT with COMPANY ANCIENT and fix the page number in the rule:To represent Ancient-Invigilus Sirae Karagon in all instances, the COMPANY ANCIENT datasheet should be used, as on page 126 of Codex: Space Marines. When doing this, replace the <CHAPTER> keyword with the RED SCORPIONS keyword. I agree with you but he is modeled wielding a power sword and the company ancient cannot take it Link to comment https://bolterandchainsword.com/topic/358934-sirae-karagon/#findComment-5401150 Share on other sites More sharing options...
Brother Tyler Posted October 4, 2019 Share Posted October 4, 2019 D'oh! That's what I get for giving a hasty answer. Until Forge World provides an update, you'll probably have to limit his use to friendly games where your opponent allows your "Company Ancient" to have a power sword instead of a boltgun. Or you could simply field him as a Lieutenant...? Link to comment https://bolterandchainsword.com/topic/358934-sirae-karagon/#findComment-5401432 Share on other sites More sharing options...
Mcha0s92 Posted October 4, 2019 Author Share Posted October 4, 2019 D'oh! That's what I get for giving a hasty answer. Until Forge World provides an update, you'll probably have to limit his use to friendly games where your opponent allows your "Company Ancient" to have a power sword instead of a boltgun. Or you could simply field him as a Lieutenant...? I guess that's the only way... tried to email the rule team but no answer still Link to comment https://bolterandchainsword.com/topic/358934-sirae-karagon/#findComment-5401481 Share on other sites More sharing options...
