Fixing clippers
  1. To still get some (re-)use out of them: They're still usable even without the spring and handle parts - just have to open them manually and maybe wrap some tape around the handles (or slide the handle parts back on)
  2. To repair: Insert the left side of the spring into the hole on the left, the right side of the spring should wrap around the pin on the right. Push the handle parts back on and you should be fine. This could get a bit fiddly though.
Unless the handle parts are broken - in that case you're stuck with 1. or have to grab new clippers.
