regraham Posted October 8, 2019 Share Posted October 8, 2019 Hey all, I wrote a guide on the best airbrush for miniatures. Could do with some feedback from the community. I want to compile the best guide on new starters or upgrades getting airbrushes and was wondering what everyone wants to know and whether it's covered in the article? What Considerations did you make when buying a new airbrush? https://www.fauxhammer.com/top-10/best-airbrushes-for-miniatures-wargames-models/ Link to comment https://bolterandchainsword.com/topic/359060-the-best-airbrush-for-miniatures/ Share on other sites More sharing options...
Trevak Dal Posted October 11, 2019 Share Posted October 11, 2019 I've just purchased a badger Patriot after using the airbrush that came with my compressor (a replica of iwata made by master if I'm not mistaken) So I'm a novice in firearms, but the break down of (iwatas) and that master airbrush knockoff was like, a mainline modern polymer handgun (Glock etc) easy take down, easy reassembly. The badger is a little like taking a 1911 apart, though I've gotten used to it. While cleaning the badger I popped out the little Teflon needle...I forget what it's called, but I was able to get it back in after a few YouTube searches. Link to comment https://bolterandchainsword.com/topic/359060-the-best-airbrush-for-miniatures/#findComment-5405404 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted October 16, 2019 Share Posted October 16, 2019 Would you recommend this brush for a beginner? Its pretty cheap, so if it gets wrecked, like you reckon a beginner brush will eventually, no big problem. Its gravity fed, but the main upside for me is that it's single action, I have dispraxia, so I feel it will be easier to get to the hang of. At this point it's worth mentioning that only thing I'll ever use it for is base painting, stencil work and maybe camo. I have no desire to preshade or do zenithal highlighting or any of the advanced techniques, I like edge highlighting with a brush, recess shading and drybrushing. Link to comment https://bolterandchainsword.com/topic/359060-the-best-airbrush-for-miniatures/#findComment-5408335 Share on other sites More sharing options...
Imren Posted October 16, 2019 Share Posted October 16, 2019 If you only going to do the following: prime base coat varnish Then you might as well just get a cheap no name chinese airbrush, or a Badger Patriot 105 or a Iwata HPCS if you want to go a bit fancy. If you want to throw yourself into: preshading highlighting OSL detail work with an airbrush then I recommend to get an airbrush with a smaller cup (less front heavy and better viewing sighting arc) and smaller needle size, such as Badger Sotar 20/20 and Iwata CM-B (the latter is quite expensive). I have tried them all and If I had to pick one I'd probably go with the Badger Sotar due to ease of needle extraction (no need to remove back housing), short distance between nozzle and trigger (better control) and the small cup size. Link to comment https://bolterandchainsword.com/topic/359060-the-best-airbrush-for-miniatures/#findComment-5408401 Share on other sites More sharing options...
