Different type of scale models
Whitelion
I have seen that for scale models of titans there are different scales, which however are not indicated in a classical way (for example 1: 200), but are classified with names (for example Epic Scale or Adeptus scale). Please could you explain to me the main scales of the models which are they and what are the differences?
https://bolterandchainsword.com/topic/359064-different-type-of-scale-models/
ok thanks, but 6-8mm scale models iirc, what 6-8 mm? Is the thickness of base?
to expand... x mm scale models means an average human will be that many mm from base (or feet) to the eyes (or top of the head)*
*yes this means you can get several different size models all in the same 'scale'...
dont even get started on the difference between heroic and true scale .....
these two links can help explain better than I can
http://theminiaturespage.com/ref/scales.html
https://normanminiatures.wordpress.com/miniature-scales/
The scales for (most of) GWs game systems are as follows:
  • 54mm (1:30): Inquisitor (OOP)
  • 28mm (~1:58): Wh40k, AoS (resp. WHFB), Necromunda, Warhammer Quest, Blackstone Fortress, Warcry, Kill Team, Space Hulk (OOP), Gorka Morka (OOP) ...
  • 8mm (1:200): Adeptus Titanicus, Aeronautica Imperialis
  • 6mm (~1/285): Epic (OOP)
  • unknown (to me): Battlefleet Gothic (OOP, I don't know if the spaceship models are to scale or just approximation), Dreadfleet (OOP, naval battles in Warhammer Fantasy), Warhammer Historicals (OOP, not sure if it's 28mm)
* OOP = out of print/production, no longer produced/available
Here's the thing, scales for miniatures are measured based either on how tall a 6ft human would be in that scale  OR what 1 inch equals in that scale. So for 1:30/54mm, 6ft = 54 inches, and a 6ft man would be about 2.4 inches. Meanwhile, in 1:200, 1 inch actually represents 200 inches in scale, so a 6ft man would be 0.36 inches tall. That's why everything is much smaller in adeptus scale.
BFG is not to scale, the ships are just representations, as per the rules for the game- the tip of the stem of the base is actually the size of the ship due to the vastness of space. so a 15km long ship is roughly the size of a pin head.
the models themselves are in something a bit different. its in the 1/thousands.
Thank you very much, you have been very clear.
But .... 1:30? seriously? But on an Adeptus scale of 1: 200, isn't a warlord 56 cm tall? When they play war games do they do it in the football field?
It's a fantasy game. No one cares if the scaling is 'correct'. That's why they call it 'adeptus' not '1:200'.
