BrainFireBob Posted October 14, 2019 Share Posted October 14, 2019 Greetings Frater. I was playing around with Battlescribe during work today- does the Dreadclaw Drop Pod Assault rule allow the same turn 1 shenanigans that the loyalists now get? I see no restriction on dropping Turn 1; the rule specifies "at the end of any of your movement phases, deploy no closer than 9"", just like the loyalist version. Did I miss an update, or is there something Battlescribe isn't updating, or does Chaos finally have a comparable drop pod? Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/ Share on other sites More sharing options...
Gederas Posted October 14, 2019 Share Posted October 14, 2019 Nope. We don't get Turn 1 Drop Pods, because..... Reasons Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407496 Share on other sites More sharing options...
BrainFireBob Posted October 14, 2019 Author Share Posted October 14, 2019 Which rule? As I said, at work, and the wordings are the same Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407500 Share on other sites More sharing options...
MegaVolt87 Posted October 14, 2019 Share Posted October 14, 2019 Which rule? As I said, at work, and the wordings are the same Yeah, just checked myself, wording is pretty much the same between the index and the 2.0 SM dex. Well, whats the problem then? Well its 200pts without guns and takes up a a FA choice. I think you would be better off with the termite drill honestly. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407526 Share on other sites More sharing options...
BrainFireBob Posted October 14, 2019 Author Share Posted October 14, 2019 115. Not bad for a dread or a pair of dev battery units Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407546 Share on other sites More sharing options...
CrystalSeer Posted October 14, 2019 Share Posted October 14, 2019 The rules for how many units can be in reserve and when they can come in are all in the BRB/FAQ/CA. SM drop pods are given specific exception to these; dreadclaws are not. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407554 Share on other sites More sharing options...
BrainFireBob Posted October 14, 2019 Author Share Posted October 14, 2019 Exception to percent of army. I am asking if they can alpha strike, based on their drop pod rule Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407558 Share on other sites More sharing options...
CrystalSeer Posted October 14, 2019 Share Posted October 14, 2019 Exception to percent of army. I am asking if they can alpha strike, based on their drop pod rule Basic matched play rule is no deep-strike (Alpha-strike) on T1. So without an expressly written rule, have to wait until T2 and follow all the other restrictions. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407561 Share on other sites More sharing options...
BrainFireBob Posted October 15, 2019 Author Share Posted October 15, 2019 Instead of deploying this model with the rest of your army, you can set it up, alogn with any units embarked within it, in orbit, ready for a Drop Pod Assault If you do so, it can make a Drop Pod Assault at the end of any of your Movement phases. When it does so, set it up anywhere on the battlefield that is more than 9" from any enemy models. Any models embarked inside must immediately disembark, but they cannot be set up within 9" of any enemy models. Specific over general Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407605 Share on other sites More sharing options...
Khulu Posted October 15, 2019 Share Posted October 15, 2019 Literally every deep strike rule says that. They cannot come in turn 1 unless they are given explicit permission to do so. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407767 Share on other sites More sharing options...
Khornestar Posted October 15, 2019 Share Posted October 15, 2019 Instead of deploying this model with the rest of your army, you can set it up, alogn with any units embarked within it, in orbit, ready for a Drop Pod Assault If you do so, it can make a Drop Pod Assault at the end of any of your Movement phases. When it does so, set it up anywhere on the battlefield that is more than 9" from any enemy models. Any models embarked inside must immediately disembark, but they cannot be set up within 9" of any enemy models. Specific over general Nothing you mention allows you to deep strike it turn 1. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407853 Share on other sites More sharing options...
BrainFireBob Posted October 15, 2019 Author Share Posted October 15, 2019 "Any of your movement phases" means *any,* which is why I am asking for the specific reference Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407873 Share on other sites More sharing options...
GreaterChickenofTzeentch Posted October 15, 2019 Share Posted October 15, 2019 "Any of your movement phases" means *any,* which is why I am asking for the specific reference Tactical Reserves, September FAQ Update, pg. 3, paragraph 2. "Furthermore, in matched play games, units that are not placed on the battlefield during deployment in order to arrive on the battlefield mid game as reinforcements cannot arrive on the battlefield during the first battle round." When this was a beta rule it was described as a new blanket rule overriding specific datasheets unless exempted. Drop Pods have an exemption that names this specific rule ("Tactical Reserves"). Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5407969 Share on other sites More sharing options...
MegaVolt87 Posted October 15, 2019 Share Posted October 15, 2019 Drill would still be better than current dredclaw IMO. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5408141 Share on other sites More sharing options...
Khornestar Posted October 16, 2019 Share Posted October 16, 2019 It SHOULD work on turn 1, as should the kharybdis, but should is a funny thing, and FW units don't really get the same kind of attention since they're more of an afterthought. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5408213 Share on other sites More sharing options...
Jolemai Posted October 16, 2019 Share Posted October 16, 2019 Bear in mind that there are three "game modes" of 40k: Open Play, Narrative Play, Matched Play. The rules on the Datasheet says how the model deploys and this is what happens in Open and Narrative. Matched Play deployment from "Reserves" is modified by the above post by Greater Chicken. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5408246 Share on other sites More sharing options...
BrainFireBob Posted October 16, 2019 Author Share Posted October 16, 2019 "Any of your movement phases" means *any,* which is why I am asking for the specific reference Tactical Reserves, September FAQ Update, pg. 3, paragraph 2. "Furthermore, in matched play games, units that are not placed on the battlefield during deployment in order to arrive on the battlefield mid game as reinforcements cannot arrive on the battlefield during the first battle round." When this was a beta rule it was described as a new blanket rule overriding specific datasheets unless exempted. Drop Pods have an exemption that names this specific rule ("Tactical Reserves"). Thank you. 5 month old means combing through 6 books is problematic Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5408821 Share on other sites More sharing options...
GodEmperorOfMankind Posted October 16, 2019 Share Posted October 16, 2019 So open play and narrative play you can, matched play in 8th you can't. Or come battle in Age of Darkness and fight the legions of the false emperor in the name of the Warmaster! We can Drop Pod Assault with Dreadclaws there: https://whc-cdn.games-workshop.com/wp-content/uploads/2018/07/Horus-Heresy-Drop-Pods-Errata-v1.0.pdf Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5409008 Share on other sites More sharing options...
Khornestar Posted October 16, 2019 Share Posted October 16, 2019 Could not be less interested in the 7th edition ruleset, as cool as the HH is. Link to comment https://bolterandchainsword.com/topic/359198-dreadclaw-drop-pods-drop-pod-assault/#findComment-5409025 Share on other sites More sharing options...
