Invictor Warsuit: Competitive?
Magnets! Then you can mix and match :D
Depends how you wanna run them
Mine have flamers to turn up the heat T1
I haven't actually played my list yet though so can't comment on effectiveness
A friend has had good success with running the dakka versions as UMs and IHs
Problem with that is that the kit seems difficult to magnetize and I haven't seen a good tutorial on how to do it easily otherwise I would
It's super easy! In fact here's one I've prepared earlier :tu:
Thanks to seridales advice and the struggle of my friend trying to do it an alternate way was able to easily magnetise the arms. Might even use the same method on my 2nd redemptor. Here's a quick break down of how I did it.
The one thing which a picture couldn't show was that I used the original hollow pins as a guide to drill a pilot hole before shaving them off (which is what the first pic is) from there it's just placing magnets.
I used 3mm magnets which required the gun slots to be slightly drilled out the next sized down in imperial might have fit without drilling
