Ordo Sinister Warlord Psy-Titan
Whitelion
in fact it makes sense to use the rules of vortex torpedoes, even if on lexicanim, wikia and in the novel they speak of an area of destruction much greater than that of a vortex missile. Perhaps I could at least double the area by targeting more units.
For the emperor, I don't know, I never read datasheets about it, it would be a gamble to assume the strength of the armor or the power of the weapons. In the past how was it differentiated from a warlord?
The arm weapons should be
Hellstorm: buffed up gatling, increase strength
Plasma anihiliator: idem
Vengeance canon: two shot volcano
Missile arm: 6x vortex missiles
In the carapace you could put two or three warlord weapon sets of the same type
Void shields depends on the rules in some it has 8 in others 12
More hit points and armour?
For the emperor titan I think we could use the stadard values taken from Apocalypse (http://darogscompany.blogspot.com/2013/04/new-rules-for-emperor-battle-titan-by-gw.html)
The Hellstorm cannon is credited for strength 9 per shot, all other weapons are D.
Instead for the Psy Black Hole cannon of the Warlord Psy-Titan I think it would be right to give it the power of a vortex missile but with area damage and not single drive, because in the novel it shows that it hits on a vast area with destructive power.
P.S: Forgive my ignorance, I have some little difficulty understanding the effect of the force D and G weapons of the latest version of the game. Could you give me some advice about it? I thank you in advance
I think multiple shots is a better way of representing the raygun fire pattern described in the book.  (I also selfishly don't like blast weapons in AT because you can't target them).  I really should invest time in getting my psy-titan going.  There's a 3d printable lion shoulder on Thingiverse if you guys have resin printers but I was actually going to spray the flat shoulder bit silver and let a coworker who can actually draw ink in the lion's head in 2d with a Micron pen.  I also thought Dark Angel green and Warp Lighting contrast paints would look cool swirled around the armor plates.
