Master of ambush and seize initiative
angrom
Hi all.
I would just like to confirm one detail about our rules.
As I understand it seize the initiative for the first turn happen at the beginning of the first round before first turn begin as well as our warlird trait master of ambush. So it means we can wait to see who definitly gets the first turn before using it am I right?
Hi all.
Yeah it occurs after the seize roll which is why it is so strong.  When playing filthy casuals you should be prepared to refute any claims otherwise although I'm not sure where exactly this has been address by GW.  It is in one of the many FAQs somewhere.  :(
I typically point out to people that First Turn roll and Seize the Initiative are both part of the deployment portion of the game. MoA and our other good stuff explicitly states that it occurs after that but before the first round begins.
I just looked and Deployment is its own section in the mission descriptions, and so is First Turn.  Under First Turn is where it lists one should make the roll to seize.  MoA is "At the start of the first battle round, before the first turn begins".  Is it not reasonable to argue that when the First Turn section starts then the first turn has begun, i.e. the first turn begins before seizing?  Or am I missing something?
I do have the rules handy.  Here's a sample from the CA18 mission "Narrow the Search":
DEPLOYMENT
The players roll off and the winner determines
which of the standard deployment maps is
used in the battle (see the Warhammer 40,000
rulebook) and picks one of the deployment
zones for their army. Their opponent uses the
other deployment zone.
The player who did not pick their deployment
zone then deploys their entire army first.
Their opponent then deploys their entire
army. A player’s models must be set up wholly
within their deployment zone.
FIRST TURN
The player who finished setting up their army
first chooses who takes the first turn. If they
decide to take the first turn, their opponent
can roll a dice: on a 6, they seize the initiative,
and they get the first turn instead
Does the first turn not begin where it says FIRST TURN?
