Slasher956 Posted October 26, 2019 Share Posted October 26, 2019 Ok the power is called focus will....how does it work Focus will. WC 6. Pick friendly psyker in 6. Until end of phase, when a deny test is take add 2 to the total. Edit - so my read is you add 2 to the deny test, which is taken by the opponent so why would you? Or is it you add 2 to the target the deny test needs to get? Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/ Share on other sites More sharing options...
Brother Tyler Posted October 26, 2019 Share Posted October 26, 2019 You're adding 2 to the psyker's Deny the Witch test (see page 178 of the rulebook). Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415088 Share on other sites More sharing options...
Slasher956 Posted October 26, 2019 Author Share Posted October 26, 2019 The deny test is done by the opponent and is to beat the result of the psychic test. So adding 2 to deny test benefits the opponent. I mean you are doing the power in your player turn and it lasts that phase, RAW the power makes no sense Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415100 Share on other sites More sharing options...
Dam13n Posted October 26, 2019 Share Posted October 26, 2019 After looking for a quoted actual wording of the rule, it looks like it should work like this: The friendly psyker you select as the target adds 2 to any deny the witch tests that psyker takes until your next psychic phase. Meaning that during your opponents next psychic phase you will get the +2 bonus when the affected psyker attempts to deny the witch. When you ask a question like this the complete wording of the rule is vital to answering that question. Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415105 Share on other sites More sharing options...
Slasher956 Posted October 26, 2019 Author Share Posted October 26, 2019 After checking the actual wording of the rule, it works like this: The friendly psyker you select as the target adds 2 to any deny the witch tests that psyker takes until your next psychic phase. Meaning that during your opponents next psychic phase you will get the +2 bonus when the affected psyker attempts to deny the witch. When you ask a question like this the complete wording of the rule is vital to answering that question. warp charge value of 6. If manifested, select one friendly <craftworld> Psyker model within 6” of this psyker. Until the end of this phase, when a deny the witch test is taken for that model, add 2 to the totalOk here’s the wording (sorry was cooking so couldn’t type it out).... it’s page 47 of the runes of fortune in Phoenix rising As you can see it’s for the phase (not round)it’s cast in and it adds to the deny test..... pointless as far as I can see.... Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415125 Share on other sites More sharing options...
Dam13n Posted October 26, 2019 Share Posted October 26, 2019 Ok, in which case it makes that psyker's powers more difficult to deny. So if a focussed willed psyker casts on an 8, an opposing psyker would count it as a 10 instead, making it more difficult to deny. It's awkwardly worded, but I guess they didn't want to make casting easier, just denying harder. Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415163 Share on other sites More sharing options...
Slasher956 Posted October 26, 2019 Author Share Posted October 26, 2019 That’s what I took RAI to be... but RAW needs “score required” to be added Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415166 Share on other sites More sharing options...
Dam13n Posted October 26, 2019 Share Posted October 26, 2019 So, it's a rule that hasn't been properly proof-read and needed a "day 1 errata" to clarify things, that isn't out yet. [shrug]No surprise there.[/shrug] Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415168 Share on other sites More sharing options...
Panzer Posted October 27, 2019 Share Posted October 27, 2019 Ok, in which case it makes that psyker's powers more difficult to deny. So if a focussed willed psyker casts on an 8, an opposing psyker would count it as a 10 instead, making it more difficult to deny. It's awkwardly worded, but I guess they didn't want to make casting easier, just denying harder. ^this The wording is clumsy, but RAW nothing speaks against this interpretation and as you already noticed it not making sense otherwise it would also be RAI. No problem, just weirdly worded. The alternative would be that RAI is the power lasting until your next psychic phase like other buff powers, making it easier for you to deny an opponents power instead of making it harder for the opponent to deny your power, however that would require an Errata as it explicitly says "this phase". Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415339 Share on other sites More sharing options...
dode74 Posted October 27, 2019 Share Posted October 27, 2019 A psyker can attempt to resist a psychic power that has been manifested by an enemy model within 24" by taking a Deny the Witch test – this takes place immediately, even though it is not your turn. To do so, roll 2D6. From BRB page 178. A model takes a Deny the Witch test when it attempts to resist an enemy model's psychic power. So it is for when your psyker tries to deny enemy casts. Which is still stupid because it is only in your phase, and the enemy can't cast in your phase (that I am aware of), meaning it does nothing. I suspect it is intended to make your psyker better at denying and should therefore be "until the start of your next psychic phase". Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415617 Share on other sites More sharing options...
Slasher956 Posted October 27, 2019 Author Share Posted October 27, 2019 As said I don’t feel like it is supposed to last till the next game roundif you read the italics (fluff) of the spell it’s about the casting psyker helping the other one ...as Dam13n said it looks like GW wanted the other models powers harder to counter rather than easier to cast (as that’s already done by a strat anyway)...anyway it’s already been thrown at GW (and not just by me on FB :p) so I expect it to be errated so it works under RAW in a couple of weeks when the FAQ goes up. Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415651 Share on other sites More sharing options...
dode74 Posted October 27, 2019 Share Posted October 27, 2019 I'm not sure the italics are that helpful: The psyker channels their mind to aid a fellow seer. Aid him to do what, exactly? I don't think it makes it easier for him to cast, but easier for him to Deny. Hence I suspect the intent is that it goes until the next turn. I look forward to errata... Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5415665 Share on other sites More sharing options...
Wulf Vengis Posted November 14, 2019 Share Posted November 14, 2019 I see this as a difficult read regardless of RAW/RAI. It's EITHER: Granting a friendly Psyker a bonus of +2 to their DtW rolls (which as stated doesn't make sense in the course of how the game plays). OR Its increasing the difficulty an enemy unit has to DtW against a friendly psykers psychic abilities by +2 (which does not appear to be what the RAW is trying to say). Eratta required. But i would not hold anything against an opponent trying to use either of these methods until an errata. Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5426644 Share on other sites More sharing options...
wildweasel Posted November 26, 2019 Share Posted November 26, 2019 Errata is up: https://www.warhammer-community.com/wp-content/uploads/2019/11/7f2bbe02.pdf It’s +2 to the targeted model’s Psychic tests for the phase. Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5434921 Share on other sites More sharing options...
Slasher956 Posted November 27, 2019 Author Share Posted November 27, 2019 so this with the craftworld ability to count 1 as a 2 gives a min test of 6 on a roll of a double 1! The Craftworld have returned to auto casting psychic powers :p! Link to comment https://bolterandchainsword.com/topic/359477-pr-new-craftworld-psychic-power-no-5/#findComment-5435374 Share on other sites More sharing options...
