Wulf Vengis Posted May 11, 2020 Author Share Posted May 11, 2020 Yo, kids will teach you that things can be broken in ways you've never realized. Link to comment https://bolterandchainsword.com/topic/359598-brushes-and-other-returning-questions/page/2/#findComment-5520016 Share on other sites More sharing options...
Wulf Vengis Posted May 13, 2020 Author Share Posted May 13, 2020 So, I'm going to bite the proverbial bullet here and buy some testors gloss black (model master custom spray enamel). It's in stock for delivery and i can expect it to arrive before some time late June. This will allow me to begin priming the test models. Link to comment https://bolterandchainsword.com/topic/359598-brushes-and-other-returning-questions/page/2/#findComment-5521080 Share on other sites More sharing options...
Wulf Vengis Posted May 20, 2020 Author Share Posted May 20, 2020 What would be a good glue for the trifecta of plastic/resin/pewter? I've always used kra-z-glu and loctite, the squeezey tubes, the foil rollup tubes and the plastic side button squeezer thing. I don't particularly care for any of these options however and am curious as to what other options some of you may use. But i had an unknown brush-on glue once, ONCE, it was unlabeled and it was glorious. Wish i knew what it was. Link to comment https://bolterandchainsword.com/topic/359598-brushes-and-other-returning-questions/page/2/#findComment-5524467 Share on other sites More sharing options...
lhg033 Posted June 3, 2020 Share Posted June 3, 2020 I generally always use loctite control gel for things plastic glue doesnt work on - mainly magents but ocasionally resin/metal/fingers.... I like the fact it is easy to control (very very rarely glue get too much glue out etc) and seems pretty solid. Loctite do do a brush on glue as well, brush is part of the cap - i used this before i switched to the gel version Link to comment https://bolterandchainsword.com/topic/359598-brushes-and-other-returning-questions/page/2/#findComment-5534445 Share on other sites More sharing options...
Imren Posted June 3, 2020 Share Posted June 3, 2020 What would be a good glue for the trifecta of plastic/resin/pewter? I've always used kra-z-glu and loctite, the squeezey tubes, the foil rollup tubes and the plastic side button squeezer thing. I don't particularly care for any of these options however and am curious as to what other options some of you may use. But i had an unknown brush-on glue once, ONCE, it was unlabeled and it was glorious. Wish i knew what it was. I suggest 2-component epoxy glue with 5 min hardening time. It is less brittle and much stronger than superglue (cyanoacrylate). Unless you build lot of large Forgeworld vehicle kits, this one will last you a lifetime used sparingly: https://www.amazon.com/Pacer-Technology-Zap-Z-Poxy-Minute/dp/B00SXJJ36W/ref=sr_1_1?dchild=1&keywords=zap+5+min+epoxy&qid=1591183557&sr=8-1 I'd also suggest to pin the faces to be glued for additional strength, especially long protruding parts with small contact area, for this I find 1 mm brass rod with 1 mm drill work best, brass rod is soft enough to not damage fine cutting pliers but strong enough to withstand mechanical stress. Link to comment https://bolterandchainsword.com/topic/359598-brushes-and-other-returning-questions/page/2/#findComment-5534455 Share on other sites More sharing options...
