ShinyRhino Posted November 1, 2019 Share Posted November 1, 2019 Anyone used the spare bits from the Infiltrators/Incursors kit to turn the E2B Reivers into additional models yet? Looking at the sprues (my box is still at the FLGS waiting for me), you get four extra carbines, four extra pack antennae and full sets of heads for whichever version you don't build from the sprues. The only WYSIWYG hurdle is the combat blade sheaths for Incursors go on a thigh where the Reiver legs already have pouches. Maybe build the Incursors from the kit and the extra Infiltrators from the Reiver bodies? I'm trying to maximize my dollars and bits, and bits buying bodies and backpacks is more expensive than E2B kits. Link to comment https://bolterandchainsword.com/topic/359613-easy-to-build-reivers-into-infiltratorsincursors/ Share on other sites More sharing options...
Bryan Blaire Posted November 2, 2019 Share Posted November 2, 2019 I haven't done it yet, but it wouldn't be hard - all the arms and pauldrons are separate on the E2B Reivers and you would only need to snip off the pegs that the arms normally go on, then make sure the surface is nice and flat to attach the Infiltrator arms. Link to comment https://bolterandchainsword.com/topic/359613-easy-to-build-reivers-into-infiltratorsincursors/#findComment-5418431 Share on other sites More sharing options...
ShinyRhino Posted November 2, 2019 Author Share Posted November 2, 2019 I found a bunch of examples on Instagram. It's doable and looks quite good. Link to comment https://bolterandchainsword.com/topic/359613-easy-to-build-reivers-into-infiltratorsincursors/#findComment-5418697 Share on other sites More sharing options...
Custom Hero Posted November 3, 2019 Share Posted November 3, 2019 The E2B Reivers have their combat blade sheaths behind the torso. It shouldn’t be too hard to use you extra pieces with these bodies. I’ve mostly used them to convert/kitbash several squads from the phobos line in order to save a little cash. Link to comment https://bolterandchainsword.com/topic/359613-easy-to-build-reivers-into-infiltratorsincursors/#findComment-5419428 Share on other sites More sharing options...
