Zenithal priming : which paints ?
Hi brothers,
I'm planning to treat me an airbrush for Chistmas and I will begin with priming and zenithal priming. I've already seen several tutorials but one topic stays unclear. After the first black priming, which kind of paint should I use for grey and white zenithal highlights ? Primers or classic acrylic paints such as Ad Grey and  White Scar?
Thanks
https://bolterandchainsword.com/topic/359666-zenithal-priming-which-paints/
I have tried several blacks, grey and whites for airbrushing pre-highlights/preshades, and the best results I get when I prime black and then with a detail capable airbrush do the gradual pre-highlighting with white. I recommend the following products after testing several different ones:
  • Vallejo Mecha primer black
  • Com art opaque white
Mecha primer is the smoothest and most durable primer I have found. Make sure you let it cure for 24h after application and before painting anything else (this goes for all primers).
Com art opaque white is the least granular speckly white paint I have found, Perhaps Tamiya flat white is as good but requires thinning with Tamiya X20A thinner.
With trigger control and and general airbrushing skills you really don't need the middle stage of painting grey between the black primer and the white pre.highlighting stage. Just do your gradual pre-highlighting with white straight on black.
I'd say have some fun with it and see the effects you can get, after the primer absolutely any paint is fine.
Want to keep everything looking quite warm? Use browns and cream for the zenithal work.
Want some cold tones, use a blue/grey and a pastel blue.
Rik
You mean that you spray white paint heavier on the lighter areas and lighly on shady areas to keep black visible under the pre shading coat ?
Thanks a lot very informative !
Yes! Exactly what I mean!
Sounds dumb but for practice when you first get the airbrush, try making lines and circles on newspaper. Keeping line thickness the same trains your wrist for working distances. Keeping a steady color intensity without splatter/running works trigger control.
I scoffed at first,tried it and was pleasantly surprised.
Good luck!
