Dumah Posted November 4, 2019 Share Posted November 4, 2019 Simple question really: do they stack? Duellists: When resolving an attack made with a melee weapon by a model with this tactic against an INFANTRY or BIKER unit, an unmodified hit roll of 6 automatically scores a hit and successfully wounds the target (do not make a wound roll). Gene-Wrought Might: Use this Stratagem in the Fight phase, when a PRIMARIS INFANTRY unit from your army is chosen to fight with. Until the end of that phase, when resolving an attack made with a melee weapon by a model in that unit, an unmodified hit roll of 6 automatically scores a hit and successfully wounds the target (do not make a wound roll). Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/ Share on other sites More sharing options...
dode74 Posted November 4, 2019 Share Posted November 4, 2019 They do not say "additional", they say "a hit". I would say no. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420098 Share on other sites More sharing options...
BluejayJunior Posted November 4, 2019 Share Posted November 4, 2019 No they do not stack. Both rules have you skip a step in the resolving attacks sequence, they do not generate any additional hits/wounds. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420116 Share on other sites More sharing options...
Dumah Posted November 4, 2019 Author Share Posted November 4, 2019 A crying shame, that. I had such wonderful thoughts of Incursors scoring 4 auto wounds per 6... Ah well. I'll content myself with 2. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420149 Share on other sites More sharing options...
Khulu Posted November 4, 2019 Share Posted November 4, 2019 I don't think that would work anyway since Incursors score bonus hits with their guns and the above rules both specify melee weapons. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420282 Share on other sites More sharing options...
Dumah Posted November 4, 2019 Author Share Posted November 4, 2019 Incursors score bonus hits with their paired combat blades. You may be confusing them with Infiltrators. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420305 Share on other sites More sharing options...
Slasher956 Posted November 5, 2019 Share Posted November 5, 2019 FAQ, main rulebook page 11 top of left hand side Q: Some abilities can cause extra hits or wounds on a specific roll e.g. ‘Each hit roll of 6 scores 2 hits instead of 1’ and ‘Each hit roll of 6 scores 1 additional hit on the target’. Are these abilities cumulative?A: It depends on the exact wording of the rule in question. Rules that ‘score 2 (or more) hits instead of 1’ are not cumulative. Rules that ‘score 1 (or more) additional hits’ are cumulative. Here are some examples to show how these rules interact: 1. If a model is affected by two different rules that say that on a hit roll of 6 that attack ‘scores 2 hits instead of 1’ then a hit roll of 6 will still only result in 2 hits being scored against the target unit. 2. If a model is affected by two different rules that say that on a hit roll of 6 that attack ‘scores 1 additional hit‘ on the target, then a hit roll of 6 will result in 3 hits being scored against the target unit. 3. If a model is affected by two different rules, one that says that on a hit roll of 6 that attack ‘scores 2 hits instead of 1’ and one that says that on a hit roll of 6 that attack ‘scores 1 additional hit‘ against the target, then a hit roll of 6 will result in 3 hits being scored against the target unit. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420516 Share on other sites More sharing options...
Dumah Posted November 5, 2019 Author Share Posted November 5, 2019 FAQ, main rulebook page 11 top of left hand side Q: Some abilities can cause extra hits or wounds on a specific roll e.g. ‘Each hit roll of 6 scores 2 hits instead of 1’ and ‘Each hit roll of 6 scores 1 additional hit on the target’. Are these abilities cumulative?A: It depends on the exact wording of the rule in question. Rules that ‘score 2 (or more) hits instead of 1’ are not cumulative. Rules that ‘score 1 (or more) additional hits’ are cumulative. Here are some examples to show how these rules interact: 1. If a model is affected by two different rules that say that on a hit roll of 6 that attack ‘scores 2 hits instead of 1’ then a hit roll of 6 will still only result in 2 hits being scored against the target unit. 2. If a model is affected by two different rules that say that on a hit roll of 6 that attack ‘scores 1 additional hit‘ on the target, then a hit roll of 6 will result in 3 hits being scored against the target unit. 3. If a model is affected by two different rules, one that says that on a hit roll of 6 that attack ‘scores 2 hits instead of 1’ and one that says that on a hit roll of 6 that attack ‘scores 1 additional hit‘ against the target, then a hit roll of 6 will result in 3 hits being scored against the target unit. None of which covers rules that describe "a hit" that results in an automatic wound. But I bow to the logic that if neither rule specifies "additional hits" or "additional wounds" then it can't be cumulative. Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420518 Share on other sites More sharing options...
Slasher956 Posted November 5, 2019 Share Posted November 5, 2019 Sorry hit post too early... ment to put something to explain why I quoted that FAQ... Basically It says in the question that abilities that cause wounds on a specific roll (which your two abilities do, they auto wound on the 'to hit roll of a natural 6') work like this.... now the examples are only on hits generating more hits or attack rolls because when that FAQ entry was written that was all that was out there Link to comment https://bolterandchainsword.com/topic/359670-gene-wrought-might-and-duellists/#findComment-5420522 Share on other sites More sharing options...
