General Strike Posted November 6, 2019 Share Posted November 6, 2019 So, I want to paint my Nurgle Daemons with a cracked flesh with glowing green underneath, then goop oozing out of the cracks. I was thinking of painting the whole model a bright green color, like warp lightning, then painting the whole model with mordant earth. Does anyone forsee any issues using a paint meant for bases on a model, or has anyone tried it? Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/ Share on other sites More sharing options...
Bryan Blaire Posted November 6, 2019 Share Posted November 6, 2019 Well, it seems like it has to dry in the horizontal orientation to get the cracking effect otherwise it will drain down to the base of the model from gravity, so you would probably need to have some way to hold the model still while the paint pools, dries, and cracks. There was a reddit thread where the technique was used to make a magma with black cracking surface effect on a Terminator, so it can be done. Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5420936 Share on other sites More sharing options...
Fajita Fan Posted November 6, 2019 Share Posted November 6, 2019 You might be better off with mixing paint with actual crackle medium. Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5420950 Share on other sites More sharing options...
MegaVolt87 Posted November 6, 2019 Share Posted November 6, 2019 Well, it seems like it has to dry in the horizontal orientation to get the cracking effect otherwise it will drain down to the base of the model from gravity, so you would probably need to have some way to hold the model still while the paint pools, dries, and cracks. There was a reddit thread where the technique was used to make a magma with black cracking surface effect on a Terminator, so it can be done. That sounds like exactly what I need to model flesh metal exoskeleton for an IW lord. Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5420985 Share on other sites More sharing options...
Kierdale Posted November 6, 2019 Share Posted November 6, 2019 Using a hair dryer you can get those paints to crackle very soon after applying them to a model :tu: Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5421032 Share on other sites More sharing options...
General Strike Posted November 6, 2019 Author Share Posted November 6, 2019 My main worry now is that touching the model will damaged the effect and it will eventually lose the crackle. Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5421113 Share on other sites More sharing options...
Bryan Blaire Posted November 6, 2019 Share Posted November 6, 2019 Make sure you varnish appropriately, get it sealed well, and you should be okay. I mean I wouldn't go and start smashing my fingers on the crackle areas, or roughly grabbing the crackle areas, grasping it tight, etc., but if you are just moving it around, etc., you should be good if it is properly sealed. Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5421159 Share on other sites More sharing options...
MegaVolt87 Posted November 6, 2019 Share Posted November 6, 2019 Picking up infantry by the base and a varnish, should have no problems. Link to comment https://bolterandchainsword.com/topic/359701-mordant-earth-on-the-model/#findComment-5421322 Share on other sites More sharing options...
