Simo429 Posted November 10, 2019 Share Posted November 10, 2019 I am really struggling to get a good fit specifically with part A11, 12 and 10 and subsequently because of thie A13 and 14 are not fitting. I realise that it doesn't massivley matter because the carapace is going on BUT I want to get it right. Any suggestions for resources to better see what I am doing wrong? There's not video on youtube Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/ Share on other sites More sharing options...
Dragonlover Posted November 10, 2019 Share Posted November 10, 2019 Can you show us some pictures of yours? Personally I don't think I had any real problems with those bits, my only real advice is don't rush the sides. Glue one on, let it sit for 5-10 minutes, then do the other one. Also at the risk of sounding incredibly patronising you've trimmed all the sprue tags off right? I've had plenty of times where I'm swearing at a kit and then realise I've missed a bit... Dragonlover Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423139 Share on other sites More sharing options...
Simo429 Posted November 10, 2019 Author Share Posted November 10, 2019 Can you show us some pictures of yours? Personally I don't think I had any real problems with those bits, my only real advice is don't rush the sides. Glue one on, let it sit for 5-10 minutes, then do the other one. Also at the risk of sounding incredibly patronising you've trimmed all the sprue tags off right? I've had plenty of times where I'm swearing at a kit and then realise I've missed a bit... Dragonlover Hoping that's worked, they just don't seem to have gone together well. I haven't got any bits of sprue left on though at least. Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423149 Share on other sites More sharing options...
Mendi Warrior Posted November 10, 2019 Share Posted November 10, 2019 The answer is on the second picture: you glued the sides outside instead of inside of the floor panel. Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423160 Share on other sites More sharing options...
Mendi Warrior Posted November 10, 2019 Share Posted November 10, 2019 A12 and A11 go inside of A10. Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423162 Share on other sites More sharing options...
Simo429 Posted November 10, 2019 Author Share Posted November 10, 2019 Thanks all thats so obvious now its pointed out Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423170 Share on other sites More sharing options...
Mendi Warrior Posted November 10, 2019 Share Posted November 10, 2019 Step 5 in the instructions booklet could have been better made, it is a bit misleading. Always dry fit before gluing, especially with AT stuff (Reavers in particular), even 2 or 3 dry fits before gluing. Worst case, dedicate this warhound to Nurgle and use greenstuff to mask the mistake. Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423174 Share on other sites More sharing options...
Fajita Fan Posted November 10, 2019 Share Posted November 10, 2019 Yep, dry fit everything. The tolerances are really tight. Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423228 Share on other sites More sharing options...
Simo429 Posted November 10, 2019 Author Share Posted November 10, 2019 Step 5 in the instructions booklet could have been better made, it is a bit misleading. Always dry fit before gluing, especially with AT stuff (Reavers in particular), even 2 or 3 dry fits before gluing. Worst case, dedicate this warhound to Nurgle and use greenstuff to mask the mistake. I was missing part of the sprue so GW sent me a box for as a replacement so I'll use this as a test model but thanks Link to comment https://bolterandchainsword.com/topic/359793-struggling-with-the-warhound-chassis/#findComment-5423300 Share on other sites More sharing options...
