What is an 'ability'?
Palmu
Abilities  are rules that apply to a model and our found on the models data sheet (normally between the weapon stats and the keyword block in the section labled: Abilities).
There may be abilities that can be granted via other means such as WLT or powers...
EDIT - abilities also include the faction rules (ie space marine chapter tactics, SoB <order> convictions) and the troops objective secured.
So Abilities are anything that states its an ability.
Thanks for the answer, though the rules are still a bit unclear, since a lot of things don't state at all that they're an ability, and the rulebook occasionally refers to things as something other than an ability, such as a 'rule'.
As a more concrete example, the Canticle of Hate litany grants +2" to a Charge, but states that this does not stack with other abilities that do the same. Is a Stratagem that grants +1" Charge an ability, and is a Warlord Trait that grants +1" Charge an ability?
