Adamantium will and transports
Hi everyone,
Forgive me if there is an obvious answer to this question in the rule book. When a psychic power targets a dedicated transport containing a unit with Adamantium will, does the bonus confer to the transport?
I’m presuming not as the transport is a separate unit in its own right.
Secondly, if a beam witch fire power targets a vehicle, but passes through a unit with adamantium will do you get the bonus for deny the witch rolls?
Again, I’m presuming not, because the intended target was the vehicle.
Any thoughts?
Cadmus
https://bolterandchainsword.com/topic/360682-adamantium-will-and-transports/
Adamantium Will would not confer to the vehicle because of passengers sadly, but for the beam you would be able to get the benefit. Essentially you don't pick a target for beams, you just pick a direction really, so technically the first unit is a target as much as the vehicle is so would be able to Deny the Witch with Adamantium Will benefiting it.
