How would you field Alpharius in WH40K?
slitth
Question?
How you would field Alpharius in 40K?
Not the actual Primarch, but the warrior claiming to be Alpharius.
Would to nice to have a special character from GW?
With the I Am Alpharius Warlord Trait.
I apologise for the trite answer, but it's honestly pretty solid.
Now, if you decide you want the actual Primarch, a Daemon Prince is the most appropriate datasheet. The FW 30K model works as paired talons, while I've seen people run Guilliman's model as sword, talons, and warp bolter.
