Conquest Blightlord Terminators
Master Sheol
I bought two copies of Conquest 19 so now i have 2 Lords of Contagion and 6 Blightlord terminators
I want to keep 1 Lord as It Is now and convert One in the leader of the Blightlord unit
Then i Will have a Total of 6 terminators more to Build a 7 men unit
How do you suggest to modify them to make a legal unit from them?
https://bolterandchainsword.com/topic/360978-conquest-blightlord-terminators/
You would have to change the second Lord and one of the Heavy Flamer-ish guys into some permutation of Combi-Bolter + Melee Weapon. You could maybe change one of them into a guy with a flail. Maybe using a piece of jewelers chain? (Unsure of translation here) I would use the Flamer guy for this, as his left arm has a usable position. The second Lord should be easy, replace the scythe blade with an axe blade and exchange the ball thing in his hand with a combi-bolter.
Yes
I guess It could work and i want One guy with that flail
My DG codex is already ordered and waiting for it
I guess i am gonna buy some alternative heads from some bits sellers too and i am gonna do some arms swaps to have more varied models
I had a similar idea. Using Felthius as Deathshroud, changing one of them so the other can still be the original Felthius, most likely a head swap etc. With the two heavies I'll keep one as is and maybe magnetise his arm if possible and proxy as a foul spawn (as someone suggested), the other will have an arm change.
I purchased the flail variant singularly on ebay and it luckily came with axe and combi arms to switch the above heavy variant.
I'll likely buy the full box at some point, but this was my quick fire and cheaper way to getting the unit started.
