Printed vs Digital Chapter Approved 2019
I noticed that in my digital copy of CA19, the datasheet for the •new• Keeper of Secrets is messed up. The snapping claws says to make a number of attacks with the claws as shown in the chart above (the battle damage). But in CA19 the battle damage only shoes M, S and A. No mention of snapping claws. (And the datasheet in the box had higher M and S is not reduced by battle damage).
Does the printed version of CA19 contain the same error or does the KoS in the printed version contain the correct and up to date datasheet for the KoS?
I’n in that process right now. I have Shalaxi and 2 KoS in my list. The thing is the CA19 datasheet has lower move AND no snapping claws.
Cut-off is on the 12.1 and the TO has as a rule of thumb, to use the latest printed datasheet (can’t blame him for that).
It is sooo boring that GW just copy-pasted the battle damage from codex daemons... it makes the KoS soo much worse.
Edit: lower move and the KoS offensive power is totaly crippeled when it loses: move, strenght, snapping claws and regular attacks.
On Facebook they said they'll release a CA19 FAQ in the not so distant future so you might end up lucky.
It worked out kind of well. The TO ruled to use the previously printed copy (datasheet from the box) unless GW releasees an update/errata to CA19, since the datasheet in CA19 is clearly wrong. But I still hope GW gets it done before the tournament.
