Iron Warriors Bikers
Dhar'Neth
Personally, I would obtain one more bike, and do two squads of three, plasma-plasma-combi-plasma.
SO cheap for a decent harassment unit. Enough firepower to actually do something, not so much that they're a blazing target. And Chaos needs fast.
This or just a unit or four with triple plasma with what you have. You would probably shuffle points around, so 3-4 would be good size unit.
I've been running 6 with just combi-bolters and chainswords for shredding most infantry with VotLW and Endless Cacophony. For only 140 points I don't feel too bad when they eventually get destroyed.
I am kinda put off with how much real estate the new bases take up compared to the old rectangle cav bases. So 3-4 with specials is easier to hide, your bigger stock unit doesn't really need to because they are more disposable in comparison.
Post pics when you're done making them!
Here you go! They are work in progress but I can post finished pictures if you like.
Ok, here is the squad just glued and primed silver. I will probably make another champion in the future so that I can use them as two squads. For now I decided to make the champions hand swapable so I can give him any weapon (Combi plasma in the work, I have plenty FW Combi-meltas and Combi-flamers) The special weapons will be attached to bikes so I can also swap them at will.
Many thanks for comments and ideas!
  • 2 months later...
  • 2 weeks later...
Where are the legs and bolters from?
The bolters look like the Phobos pattern from the Mark III power armour set? Not sure on the legs.
Bike mounted Bolters are from mk III plastic kit. The torso is from out of production iron warriors upgrade set (mkIII plastic torso doesn't fit the bike). The legs are from Kromlech https://bitsofwar.com/home/311-legionary-biker-legs.html .
The unit is battle ready, I attach the picture, because maybe it will entertain someone during this hard times. I really wanted to thank you all for your input, even that little bit of support  and positivity helped me to go thought all that happens nowadays. Much appreciated!
