2 Lords of Change.....crazy
I run a mixed Tzeentch Daemon and Thousand Sons list. Do you think running 2 Lords of Change at 2000 points is completely crazy? The idea has been bouncing around in my head ever since I read about an AOS Tzeentch faction that can potentially summon two or three of them over a game. It seems like a lot of points in two models, but I figured I'd ask.
https://bolterandchainsword.com/topic/361306-2-lords-of-changecrazy/
Don't forget Rule of Cool ;) At 2k you have the points, but as Khornate says don't forget to provide proper support (and of course ensure you have enough other units). It'd look great on the table top, surely earning the favour of the dice gods and Tzeentch :P
I don't see any reason why one shouldn't bring more than one Greater Daemon. If you look at just the stats they are basically the daemon version of tanks. Lots of armies bring multiple tanks/dreadnoughts/flyer/whatever.
In fact if you want your Greater Daemon to do anything at all you kinda HAVE to bring multiples since otherwise it would probably get shot off the table before it reaches the enemy. :sweat:
A problem that could present itself would be, that you can only give on of them the 3++ Robe and Incorporal Form. So the one without will be Target #1. Or you spread these two around, making both a bit harder to kill. Another option would be to Deep Strike the second LoC via stratagem.
