No Foes Remain Posted January 18, 2020 Share Posted January 18, 2020 So I'm getting near finishing my dreadnought for the L&T event but I was thinking how I'm going to do the last stage and came up with a issue as I don't really know enough about these sealing paints. My plan is to use the stormshield as a matt sealer on the model (as I don't want a shiney gunmetal just a dull one) but I was going to use some stirland mud on the base and a bit on the feet as well typhus corrosion further up to 'blend' in the mud with the model. Now this bit I was going to coat in ardcoat to make it glossy and, most importantly, look wet but will this cause problems with the stormshield sealer that has been already applied to the model? Thanks, A slightly confused No Foes Remain. Link to comment https://bolterandchainsword.com/topic/361330-ardcoat-stormshield-and-paint/ Share on other sites More sharing options...
Grotsmasha Posted January 18, 2020 Share Posted January 18, 2020 You should have no issues applying Hardcoat over the Matt finish Link to comment https://bolterandchainsword.com/topic/361330-ardcoat-stormshield-and-paint/#findComment-5463814 Share on other sites More sharing options...
Firedrake Cordova Posted January 18, 2020 Share Posted January 18, 2020 As Grotsmasha said, gloss varnish over matt varnish will result in a gloss finish (and matt varnish over gloss varnish will result in a matt finish). Link to comment https://bolterandchainsword.com/topic/361330-ardcoat-stormshield-and-paint/#findComment-5463835 Share on other sites More sharing options...
No Foes Remain Posted January 18, 2020 Author Share Posted January 18, 2020 Awesome, thanks guys. I'll just have to be carefull when applying the 'ardcoat to the muddy parts of the model. Link to comment https://bolterandchainsword.com/topic/361330-ardcoat-stormshield-and-paint/#findComment-5463857 Share on other sites More sharing options...
