Basing Done Easy
Hi everyone, I saw many people noting they had issues with getting bases done (one thing or another, etc, judgment free). I thought it might be useful to share a very simple, straightforward method. The key is an item called Crackle Paste (I use Golden brand). It's a paste that you can spread (like butter) on your bases. If it is a thin layer then when it dries it becomes a rough texture. Thicker layers crack and form a more "parched earth" look.
Assuming one does not want to paint the bases separately from the model then one can put down a single base layers and then dry brush. Personally, I paint my bases separate: spray base color, dry brush, and done.
lqX64MWl.jpg?1
https://bolterandchainsword.com/topic/361394-basing-done-easy/
The other difference is that crackle paste is not pigmented and starts white. I let it dry and paint over it, but it can be used as an acrylic medium (my research along this avenue indicated it can take a fair bit of trial and error, hence me just painting over it).
How's the shelf life?
Really good if you keep it tightly sealed. After about a year it starts getting too dry to apply smoothly.
