Guest Posted January 27, 2020 Share Posted January 27, 2020 So got tired of priming white and then painting grey seer to then use contrast paints. So did a quick experiment on making a primer close to grey seer, 2 parts of stynylrez grey and 1 part stynylrez white gives a extremly close grey seer color but a primer also. So hopefully those that want to share a bit of time hopefully this helps. If anyone has any othe suggestions please let people know. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/ Share on other sites More sharing options...
Grotsmasha Posted January 27, 2020 Share Posted January 27, 2020 Do you not have access to GW's spray cans? Both the Wraithbone and Grey Seer sprays are Primers, and do not need a white or black underneath. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468200 Share on other sites More sharing options...
Guest Posted January 27, 2020 Share Posted January 27, 2020 Do you not have access to GW's spray cans? Both the Wraithbone and Grey Seer sprays are Primers, and do not need a white or black underneath. nope, costs a small fortune to ship and if i can get them the air quality in korea often leaves it pretty bad shape. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468201 Share on other sites More sharing options...
Bung Posted January 27, 2020 Share Posted January 27, 2020 Do you not have access to GW's spray cans? Both the Wraithbone and Grey Seer sprays are Primers, and do not need a white or black underneath. Stynylrez is one of the best airbrush primers. Its cheaper with, less waste if you already have an airbrush. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468219 Share on other sites More sharing options...
Arkhanist Posted January 27, 2020 Share Posted January 27, 2020 I've been using Stynylrez too for pre-Contrast priming too, it is a lovely robust primer to work with and lets me spray indoors when it's chucking it down (i.e. 90% of the time in England!). Currently, I airbrush from underneath with straight stynylrez grey (for shadowing), then a light top down spray of vallejo grey surface primer (very close to grey seer) with a final zenithal spray of stynylrez white. Given the translucency of contrast paints, I found a black-to-white zenithal a bit too harsh. I'll definitely use the 2:1 grey to white stynylrez idea for the mid-tone, given it'll slot it nicely since i'm already using both anyway! Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468284 Share on other sites More sharing options...
Firedrake Cordova Posted January 27, 2020 Share Posted January 27, 2020 For those in Vallejo-land the standard grey and (Mecha Colour) ivory primers are close matches to Grey Seer & Wraithbone. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468342 Share on other sites More sharing options...
Guest Posted January 28, 2020 Share Posted January 28, 2020 I've been using Stynylrez too for pre-Contrast priming too, it is a lovely robust primer to work with and lets me spray indoors when it's chucking it down (i.e. 90% of the time in England!). Currently, I airbrush from underneath with straight stynylrez grey (for shadowing), then a light top down spray of vallejo grey surface primer (very close to grey seer) with a final zenithal spray of stynylrez white. Given the translucency of contrast paints, I found a black-to-white zenithal a bit too harsh. I'll definitely use the 2:1 grey to white stynylrez idea for the mid-tone, given it'll slot it nicely since i'm already using both anyway! Please do test. I did a sample test the left (red) is grey seer, the right (green) is 2:1. You can see a slight difference. http://imgur.com/a/99GDgHA Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468732 Share on other sites More sharing options...
Fajita Fan Posted January 28, 2020 Share Posted January 28, 2020 I was told this stuff responds well to being manually brushed on so I bought some but when I try I get bubbles on the surface. Any remedies I can try? Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468751 Share on other sites More sharing options...
Arkhanist Posted January 28, 2020 Share Posted January 28, 2020 I was told this stuff responds well to being manually brushed on so I bought some but when I try I get bubbles on the surface. Any remedies I can try? t can be used by brush no problem. I do that regularly for crevice touch ups, re-doing areas that needed extra sanding etc. You do have to shake the bejesus out of Stynylrez when it's been sat for a while as it will separate quite badly. If you use it straight away after shaking, there can be some bubbles in it. Shaking it side-to-side rather than up-down can help reduce the amount of bubbles, or leave it a couple of minutes after shaking, or just put it onto your palette and moving it around a little to get the air out. If it's not bubbled paint, but only bubbling up when going on the mini - and has been recently shaken - then it's quite likely to be mold release or some other oily surface contaminant on the mini. Always best to briefly wash the minis in soapy water (plus rinse and left to dry) after sanding/mold line removal/assembly but before priming to clean off any mold release, hand oils, leftover flecks of plastic etc. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468854 Share on other sites More sharing options...
Fajita Fan Posted January 28, 2020 Share Posted January 28, 2020 Okay I get bubbles when pouring it out into a palette which I kinda stir to pop. Now I am getting bubbles when applying to the model even just dipping the brush in to wick up paint but this is even happening over paints. The weirdest part is that I don't get this with red or dark grey Vallejo brush on primer but I get it with white or bone colored Vallejo or Stynylrez primers. I haven't tried their black yet. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5468956 Share on other sites More sharing options...
Imren Posted January 30, 2020 Share Posted January 30, 2020 One word solution to these problems:.........airbrush! With airbrush you will get the thinnest, smoothest primer layer even if you're a airbrush novice. Way better than wasting time with brushing it on or spray cans. You can get a complete airbrush setup for around 100- 120 USD. In the long run, especially if you paint armies, that is a time and money saving investment. There are tonnes of airbrush tutorials on youtube to learn how to use it. Link to comment https://bolterandchainsword.com/topic/361522-stynylrez-grey-seer-alternatative/#findComment-5469932 Share on other sites More sharing options...
