Legion Glaive measures
Imren
Hi, saw no one answered your question.
The Legion Glaive is about 4.5 inches (11.5cm) tall to the top of the targeting array, sitting on its tracks. I have to magnetize my targeter, it broke off, so it could be slightly shorter if you do that.
If you leave the turret off, the exhaust stacks on the back are the tallest point at 3.25 inches (8.3cm).
Hope that helps!
Hope that helps!
Thanks alot! :)
I bought 100 mm deep pluck foam so if I pluck out a separate pocket for the turret 100 mm is well enough.
