Oxumus Prime Posted February 13, 2020 Share Posted February 13, 2020 Would guard with this trait, get a plus 2 to their save? Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/ Share on other sites More sharing options...
Trickstick Posted February 13, 2020 Share Posted February 13, 2020 I'm guessing you are asking if you can stack the wilderness survivors bonus with actual cover to get two +1s to your save. The answer would be no, as wilderness survivors doesn't technically give you a +1, it just lets you count as being in cover. So you can't be in double cover. Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5476404 Share on other sites More sharing options...
Oxumus Prime Posted February 13, 2020 Author Share Posted February 13, 2020 Cheers yeah that's what I was getting at Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5476445 Share on other sites More sharing options...
HallofStovokor Posted February 13, 2020 Share Posted February 13, 2020 Yes and no. You can spend 1 CP for take cover. That would get them a 3+ save. Only problem is that at least in the early turns you're going to be advancing a lot. If you're not running your Guardsmen into position you're not using your infantry squads to their fullest potential. Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5476540 Share on other sites More sharing options...
Galron Posted February 14, 2020 Share Posted February 14, 2020 Will work great for a fire support brigade along with the 18" rapid fire and a midfield battalion that pushes to the center while the 3rd batt goes close combat and stroming the enemy positions. Great board control to limit deep strikes as well Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5477124 Share on other sites More sharing options...
Wassa Posted February 16, 2020 Share Posted February 16, 2020 How does this interact with getting shot turn 1 by the opponent before we’ve had our turn? Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5477777 Share on other sites More sharing options...
sairence Posted February 16, 2020 Share Posted February 16, 2020 You didn't advance the previous movement phase so you should get cover. It usually doesn't matter for these rules if you actually had a chance to do the thing. Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5477779 Share on other sites More sharing options...
noigrim Posted February 16, 2020 Share Posted February 16, 2020 I'd like to try this combined with the rr type dice Link to comment https://bolterandchainsword.com/topic/361909-wilderness-survivors/#findComment-5477933 Share on other sites More sharing options...
